Question about LG Refrigerators
Preventive maintenance checklist - LG Refrigerators
    New Friend:
    Problem Solver:
  • 5 Answers
Www.lg.com/us/support
Posted on May 16, 2014
Does the 6235 need oiling
Oh YA! Indeed they all should have a 'tuneup' now and then.
What do they check??
GO to GOOGLE and search for: sewing machine service checklist
Next go to "IMAGES" and see MANY checklists of items to accomplish during a service!
Here is ONE example of a nice checklist!
http://www.amefird.com/wp-content/uploads/2010/01/Sewing-Mantenance-Check-List-2-5-10.pdf
and there is this great list too!
Learn Preventative Sewing Machine Maintenance
And ONE more:
Basic Sewing Machine Maintenance Tips From an Expert
Anthony
Jan 30, 2018 | Sewing Machines
Tip
Appliances Repair Maintenance Hints&Tips From Experts
Having some issues with your washer or dryer?
Dryer is not heating?
Oven not performing like it used to?
Refrigerator making strange noises?
Below you will find some helpful tip to help keep your appliances working their best. If you have any questions, please contact us at (404)903-1453 or via online form. Since every repair situation may be different, below are some of Atlanta Appliances Repair Maintenance Tips.
However, we recommend to go through our checklist below to make sure that the issue with your appliance may not require any repair services:
  • Make sure the appliance is plugged in and turned on. If it is not coming up, check the circuit breaker or fuses.
  • Reset and if it is necessary replace the circuit breaker or fuse and test the appliance again.
  • Make sure the water supply valve is turned on and the machine is getting water to it.
  • Make sure the door or lid is not blocked from opening or closing properly.
  • Always follow instructions for proper use and preventive maintenance - these are usually found in the operational manual that came with the appliance. If you cannot locate the manual, these can frequently be found on the manufacturer's website/contact the manufacturer directly. Appliances overuse/ misuse can lead to serious injury, please always consult with a professional when required.
Atlanta Appliances Repair 404 903 1453 Refrigerator washer dryer oven... hkkzqa5h4z-2-0.jpg" alt="write_tip-whqioz05as2vwqhkkzqa5h4z-2-0.jpg">
on Oct 31, 2014 | Kitchen Appliances - Others
2006 Chevy Equinox starts up then idle drops and almost dies for a couple seconds then back up to 800rpm. What would cause this ? How can I fix it? Any suggestions? Thanks!
First check the fuel filter. And for best results check or tune up your system.
Engine Tune-up Checklist When you bring your vehicle into Firestone Complete Auto Care for a tune-up, you are essentially asking our skilled technicians to inspect your engine, analyze vehicle performance, and make adjustments as needed. The engine tune-up checklist will include both preventative and restorative engine assessment, and final maintenance recommendations that will vary from vehicle to vehicle based on age, mileage and unique manufacturer recommendations.
To give you a better idea of what happens under the hood when you drop your car off, we've compiled a basic engine tune-up checklist:
  1. Check visual appearance of spark plugs: are they worn? What color are the insulator firing noses? An engine in good condition should have spark plugs with light tan or gray insulator firing noses. Any other color could be the sign of an engine problem.
  2. Test the performance of spark plugs. What color is the spark? Is the spark properly igniting the fuel?
  3. Check spark plug wires to make sure they are not hard or cracked.
  4. Check the fuel filter to make sure it isn't clogged or dirty.
  5. Check the engine's fuel pump for proper function.
  6. Inspect the engine's fuel injectors to make sure dirt or other deposits are not restricting the amount of fuel that can be delivered to the engine.
  7. Make sure fuel injector buildup isn't affecting how the spark plugs fire.
  8. Adjust the engine timing and idle if necessary.
  9. Check that the PCV valve isn't clogged or leaking.
  10. Inspect the vehicle's points and condenser
- See more at: http://www.firestonecompleteautocare.com/maintain/tuneup/checklist/#sthash.wdW1t9PP.dpuf
Apr 02, 2015 | 2006 Chevrolet Equinox
How do I tighten the Drive Shaft Bolt on my 2009 Toyota Corrola?
wrap crankshaft pulley with a clean rag to keep from damaging pulley while using a strap or chain wrench hold crankshaft pulley while tighten crankshaft bolt.
Jan 15, 2013 | 2009 Toyota Corolla 1.8
Power supply done but display is not
Symptom : No Image on the screen. I cannot turn on the monitor.
Checklist 1 : Is the power connected properly ?
Action : Check the power cord connection and supply.
Checklist 2 : Can you see "No Connection. Check Signal Cable" on the screen ?
Action : Check the signal cable connection.
Checklist 3 : If the power is on, reboot the computer to see the initial screen ( the login screen), which can be seen.
Action : * If the initial screen (the login screen appears, boot the computer in the applicable mode (the safe mode for Windows 98/95) and then change the frequency of the video card.
* Note : If the initial screen ( the login screen) does not appear, contact a service center or your dealer.
Sympton : I cannot see the ON Screen Display.
Checklist : Have you locked the On Screen Display (OSD) Menu to prevent changes ?
Action : Unlock the OSD by pressing the MENU button for atleast 10 seconds.
Hope this helps.
Have a good day.
Dec 08, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
What maintance should I do on 1995 bmw 525 at 180,000 mi
Hello. The BMW company has one of the most inclusive maintenance schedule of all. The BMW Maintenance System has been devised with the following objectives: maximize vehicle safety, reliability, and minimize breakdowns resulting from wear, at minimum cost. The Service Interval Light system will indicate when you are due for service based on your driving habits. In addition, there are recommendations for specific mile intervals.
The answer to your question is that is all of the recommended maintenance has been occurring all along, the 180000 mark requires the extensive INSPECTION 1. Any BMW dealership will print you off the entire checklist for the asking.
http://www.gms.cc/maintenance.htm
Nov 13, 2009 | 1995 BMW 8 Series
What are the actual recommendations for a 2003 4-runner 100,000 mile maintenance visit?
I found this link which will get you the Service Manual for your 4Runner...http://www.ezdries.net/Vidpics/4Runn...%204Runner.zipA generic checklist for any car which has reached 100,000 miles can be found here...http://www.trustmymechanic.com/100.pdf
Jun 04, 2009 | 2003 Toyota 4Runner
Looking for a service checklist
I was looking for the same thing for my 1990 Johnson 175. I did a google search for "Outboard Motor Manuals" and found a manual that talked you through maintenance, repairs and services. I'm sure you can find one for your motor as well.
Apr 07, 2009 | Boating
Repair on Datacard sp35 locate in Houston Texas
Do you have found a repairer for your datacard ?
Feb 27, 2008 | Datacard SP35 Printer
Refrigerators Logo
102 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
