Question about HP Computers & Internet
What hp 0a 60h ?
Manual
How to program a RC 401 0A remote control
Check this video.
http://www.google.co.in/url?sa=t&rct=j&q=RC+401+0A+remote+control&source=web&cd=1&ved=0CDAQtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3D36RHf-TcKNo&ei=IzEZUfbeLc3jrAex9YCwCQ&usg=AFQjCNGvPj_30Yup5-D0yCwEI9PaIvdA7Q
Feb 11, 2013 | Dynex RC-401-0A
How do i change to the recommended setting to 1280 x 1024 - 60H
Go to Control Panel and open Display, go to Settings and change the resolutions from there
Jan 26, 2011 | HP Vs17 17" LCD Flat Panel Monitor
What is the value of 0*0A? How????
It appears to be an Hexadecimal number and the value is 10.
Hex Dec
01 = 1
05 = 5
09 = 9
0A = 10
0B = 11
0C = 12
0D = 13
0E = 14
0F = 15
10 = 16
11 = 17
Nov 25, 2010 | Computers & Internet
Can emc ax150 work without the UPS cable?
I moved my AX-150 to a location that would not allow me to install the UPS as it has redundant power/UPS and you should not connect a UPS to the output of another UPS.
Without the UPS the AX-150 forces the Write Cache to be Disabled. Performance drops, form what I have tested, to around 25x slower. This is due to not just turning off the controllers write cache, but as with ALL RAID controllers, the onboard drive 8/16M write cache is disabled as well so the drives are even slower then they would be if they where not used on a RAID controller.
The write cache disable is your real killer! Actually the write cache is disabled one a week while the REQUIRED battery test is performed.
My solution was to write an APC SmartUPS Serial Emulator that talks to the AX-150 telling it that the UPS is working fine so the write cache never gets turned off, including during the weekly battery test!
Here is the needed RJ45 to DB9F. Colors are base on someone cutting off the end of a cat5 patch cable.
You can find the APC SmartUPS commands off the web.
Communications capture:
Normal Comms from/to AX-150
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
!!! Weekly Batt Test Time !!!!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
W >> !! Tests battery, like pushing the test button on the front panel
OK<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
X >> !! Self-test results
OK<0D><0A>
l >> !! Low transfer voltage
097<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
n >> !! Get Serial number
AS0632112344<00><0D><0A>
R >>
BYE<0D><0A>
!!! End of Test !!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
I would be happy to share the Delphi source and EXE with anyone that would like to use it. Do not see a place to attach files here.
Can give you snapshot of main command-response logic:
if Result = pmerGood then
begin
tRx := Engine.RxString;
if cbHex.Checked then
Msg(Engine.SeeBytes(tRx)+ ' >> ' + #$0D + #$0A)
else
Msg(Engine.SeeChars(tRx)+ ' >> ' + #$0D + #$0A);
PendingCmd := '';
Engine.CharDelay := 0;
CmdData := 'NA' + #$0D + #$0A;
if length(tRx) > 0 then
case ord(tRx[1]) of
$01 : CmdData := 'Smart-UPS 750 RM' + #$0D + #$0A;
$1A : CmdData := '#uD43127130133136uA43108110112114uI43253257261265uM432252292' + '33237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e47200153045607590oD13120oA13100oI33230240220oM13208s431HMLq4820205081114172023p483090180270360450540630000k4310TNr483000060120180240300360420E443336168ON OFF' + #$0D + #$0A;
ord('A') : CmdData := 'OK' + #$0D + #$0A;
ord('B') : CmdData := '27.40' + #$0D + #$0A;
ord('C') : CmdData := '016.2' + #$0D + #$0A;
ord('D') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('E') : CmdData := '336' + #$0D + #$0A;
ord('F') : CmdData := '60.00' + #$0D + #$0A;
ord('G') : CmdData := 'S' + #$0D + #$0A;
ord('I') : CmdData := 'FF' + #$0D + #$0A;
ord('J') : CmdData := '0F,00' + #$0D + #$0A;
ord('K') : CmdData := 'OK' + #$0D + #$0A;
ord('L') : CmdData := '126.7' + #$0D + #$0A;
ord('M') : CmdData := '128.1' + #$0D + #$0A;
ord('N') : CmdData := '125.2' + #$0D + #$0A;
ord('O') : CmdData := '113.0' + #$0D + #$0A;
ord('P') : CmdData := '000.0' + #$0D + #$0A;
ord('Q') : CmdData := '08' + #$0D + #$0A;
ord('R') : CmdData := 'BYE' + #$0D + #$0A;
ord('S') : CmdData := 'OK' + #$0D + #$0A;
ord('U') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('V') : CmdData := 'FWD' + #$0D + #$0A;
ord('W') : CmdData := 'OK' + #$0D + #$0A;
ord('X') : CmdData := 'OK' + #$0D + #$0A;
ord('Y') : CmdData := 'SM' + #$0D + #$0A;
ord('a') : CmdData := '3.!$%+?=#|.' + #$01 + #$0E + #$1A + ''')+-89>@ABCDEFGKLMNOPQRSUVWXYZabcefgjklmnopqrsuxyz~' + #$0D + #$0A;
ord('b') : CmdData := '615.3.D' + #$0D + #$0A;
ord('c') : CmdData := 'UPS_IDEN' + #$0D + #$0A;
ord('e') : CmdData := '00' + #$0D + #$0A;
ord('g') : CmdData := '024' + #$0D + #$0A;
ord('f') : CmdData := '100.0' + #$0D + #$0A;
ord('i') : CmdData := 'FWD' + #$0D + #$0A;
ord('j') : CmdData := '0375:' + #$0D + #$0A;
ord('k') : CmdData := '0' + #$0D + #$0A;
ord('l') : CmdData := '097' + #$0D + #$0A;
ord('m') : CmdData := '08/03/06' + #$0D + #$0A;
ord('n') : CmdData := 'AS0632112344' + #$00 + #$0D + #$0A;
ord('o') : CmdData := '120' + #$0D + #$0A;
ord('p') : CmdData := '090' + #$0D + #$0A;
ord('q') : CmdData := '02' + #$0D + #$0A;
ord('r') : CmdData := '000' + #$0D + #$0A;
ord('s') : CmdData := 'H' + #$0D + #$0A;
ord('u') : CmdData := '127' + #$0D + #$0A;
ord('x') : CmdData := '01/01/10' + #$0D + #$0A;
ord('y') : CmdData := '(C) APCC' + #$0D + #$0A;
ord('z') : CmdData := 'CLEAR' + #$0D + #$0A;
ord('9') : CmdData := 'FF' + #$0D + #$0A;
end;
if CmdData <> '' then
begin
Msg(Engine.SeeBytes(CmdData)+ #$0D + #$0A)
else
Msg(Engine.SeeChars(CmdData)+ #$0D + #$0A);
Engine.SendMsg := CmdData;
end;
Bob A. Hay
Mar 02, 2010 | EMC 1U UPS 120V FOR AX150 (AX150UPS120V)...
This the messagethat got Content-Type: text/plain; charset=iso-8859-1 Content-Transfer-Encoding: quoted-printable I'm trying=A0 to connect with you for a very long time, why don't you call = me or...
That is and HTML message that may not have been assembled correctly by the sender or corrupted during transmission and reception. That is not rare.
Nov 06, 2009 | Yahoo Mail
I have a Meyer mod # E-60H. Last year it seemed
You got the idea, because both the motor carbon
brushes and a weak battery is one of the major causes of your problem. So, have a check on these items.
Furthermore, also check the oil as well as the oil filter
if it needs to be replaced. When all the checks are done
and fixed, I'm sure that you will get the best result . Hope this will help you.
Oct 23, 2009 | Plumbing
S11-0a
Hi underbe
What make is the remote you need the manual for... could not find anything for s11-0a
regards
robotek
Jul 06, 2008 | Televison & Video
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
