How many gms is 10 oz? - Office Equipment & Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
That depends on what you mean by "oz."
10 English ounces is about 283.5 grams. 10 troy ounces is about 311.0 grams.
Posted on May 16, 2014
How do I figure 10% of a given amount of liquid?
Not quite teardrop.
1/10th of 3 oz = 0.3 oz
0.3 oz = 1.8 teaspoons.
Convert oz to tsp Conversion of Measurement Units
Feb 09, 2017 | Garden
I need to take 238 gm = to what in cups
You are talking about PEG-3350 powder, brand name Miralax but available in generic brands now, too. You've been told to use it for a clean-out prep for surgery or colonoscopy, right? The label says 238 Gms is en entire 8.3 oz bottle. But if you are struggling to read the label, which specifies that a cap filled to the line marked inside is equal to the recommended daily dose for constipation (17 Gms), then you should have been given a prep kit prescribed by a doctor, or told to have the pharmacist help you. The kit has a container with the powder, flavor packets, and the same electrolytes in the Gatorade, formulated to protect you from becoming too dehydrated or depleted of minerals by the process. An overdose of this could be serious--even very dangerous if taken by a child or elderly/fragile person--and yet an under-dose will leave you not fully washed out, so your exam may be useless or be cancelled.
Jul 17, 2014 | Miralax Laxative, Polyethylene Glycol...
How do I mix a 1:1 ratio
Mix equal parts of 2 ingredients, measuring them the same way, eg both measured in fl oz, or both in gms.
Apr 04, 2014 | Computers & Internet
How do you tighten the bobbin case?
Best down by your local repair guy as you need to measure 11 gms of tension. Remember there are 28gms/oz and a US cent weighs 0.1ozs. But anyway. Here's a quick and dirty test. Take out the bobbin case: should have a screw with green nail polish on it. Insert 4 cents and a full bobbin with standard bobbin thread. Thread the bobbin thread through the bobbin case tension and try and lift it off your palm. Adjust the screw until you can then loosen the screw until you can only lift the bobbincase from flat to standing on edge but not able to be lifted. Now sew.
Dec 02, 2013 | Baby Lock Esante
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Feb 24, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My keurig says I need to descale.How?
Descaling depends the size of the reservoir. I see the B60 but not the B66 at the Keurig site. The two units are apparently the same from searching the support side of the Keurig site: http://www.keurig.com .
For the Mini coffee makers, you use 20 oz of vinegar (2 10 oz cycles). For the larger Keurig units, it takes 48 oz of vinegar.
In either case, fill the reservoir with vinegar and put a large ceramic (12 oz mug for the mini unit) mug on the drip tray. Do not add a K-cup. For the B60 (and probably the B66), press the Brew button. Discard the vinegar after the cycle. Repeat the brew process until Add Water is indicated. Discard the vinegar each time. Then wait 4 hours with the unit on. Discard the remaining vinegar and rinse the reservoir. Fill the reservoir with 48 oz of water and brew several cups without a K-cup until the "Add water" message appears. Discard the water in the mug each time. Repeat the vinegar cleaning if De-scale still appears in the LCD. Run more water without the K-cup if you notice a remaining taste in the coffee after the rinse procedure.
For the mini, fill the reservoir with 10 oz of water, lift the Brewer handle and lower it after 5 seconds with no K-cup in the unit. Press the Brew button. Discard the vinegar after the cycle. After the first cycle, pour the other 10 oz of vinegar into the Cold Water Reservoir. Lift the handle and lower it after 5 seconds. Press the Brew button and wait until the light becomes steady. When vinegar starts to be dispensed, power off the unit. Wait 30 minutes. Then power on the unit and lift and lower the handle again. Then discard the vinegar after the cycle. Next run 4 rinse brew cycles with 10 oz of water each time. Discard the water each time. The unit should be ready to brew with a K-cup after the 4 rinse cycles.
I hope this helps.
Feb 22, 2011 | Keurig B66 3-Cup Coffee Maker
Does any of you know how many milliliters are in an ounce?
Here is a quick conversion chart:
100 ml = 3.3 or 3.4 oz
50 ml = 1.7 oz
30 ml = 1 oz
15 ml = 1/2 oz
10 ml = 1/3 oz
7.5 ml = 1/4 oz
5 ml = 1/6 oz
3.7 ml = 1/8 oz = 1 dram
Note that all of these are approximate; strictly speaking, 1/2 oz is 14.787 ml.
A standard perfume sample is in a 1/32 oz (1 ml) vial.
Nov 23, 2010 | Health & Beauty
At a farmer's market you buy 6 3/10 pounds of red onions and 4 1/3 pounds of yellow onions.What is the total weight of the purchase?
If you don't have a calculator to help you with the division by 16, here is a list of all the decimals relating ounces to a pound:
  • 1 oz. = .0625 of a pound
  • 2 oz. = .125 of a pound
  • 3 oz. = .1875 of a pound
  • 4 oz. = .25 of a pound
  • 5 oz. = .3125 of a pound
  • 6 oz. = .375 of a pound
  • 7 oz. = .4375 of a pound
  • 8 oz. = .5 of a pound
  • 9 oz. = .5625 of a pound
  • 10 oz. = .625 of a pound
  • 11 oz. = .6875 of a pound
  • 12 oz. = .75 of a pound
  • 13 oz. = .8125 of a pound
  • 14 oz. = .875 of a pound
  • 15 oz. = .9375 of a pound
Jun 29, 2010 | Core Learning Fractions Step-By-Step...
35 people viewed this question
jasbo
jasbo
