Question about Canon Office Equipment & Supplies
Offline dp 3030
My canon printer imagerunner 3030 is offline frequently.i have checked the printer settings also
  • 790 Answers
You can check this link for information on your printer problem
Posted on May 16, 2014
checkitright
  • 1362 Answers
SOURCE: Canon imageRunner 1023iF won't print--offline
change the cable, there is a bad connection once you put a new one it should say ready
Posted on Oct 15, 2007
Cogz
  • 1326 Answers
SOURCE: Canon imageRunner 3030 manual...
There should be one under Cannon usa.com Look for the user manuals
Posted on Feb 07, 2008
bunnydawg
  • 5158 Answers
SOURCE: free download DP-3030 driver
start your search here for the model that you have..
http://www2.panasonic.com/consumer-electronics/support
Robert
Posted on Dec 16, 2008
  • 168 Answers
SOURCE: Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Posted on Jan 03, 2009
Phonesmith
  • 113 Answers
SOURCE: Panasonic Workio DP-3030 Printer drivers required
Hello, this is the link to the driver download page.
http://www.panasonic.net/pcc/support/mfp/dp-3030/index.html#02-1
Thank you.
Posted on Mar 25, 2010
Canon ir 3030 printout will be black
Verify charge corona, when you start a new copy, open lateral door when paper is in the right of drum, then look if the drum is full covered with toner.
Dec 05, 2014 | Canon imageRUNNER 3030 Black and White...
Canon ir 3030 paper loading problem in cassette
The problem could be one of several things.
1) Check your "printer preferences" setting and make sure you have selected the CORRECT SIZE OF PAPER. For example; Letter, Legal, etc.
2) Un-install and re-install the drivers.
Hope these suggestions help.
Nov 03, 2014 | Canon imageRUNNER 3030 Black and White...
Am having an error code problem with my canon copier E000002 please help me is urgent.
FIRST TRY TO CLEAR ERROR BY GOING IN SERVICE MODE.
IF THE CODE IS REPEATING AGAIN CHECK HEATER FILAMENT OR THERMAL FUSE FOR OPEN CIRCUIT. CORRECT IT.
Jul 18, 2011 | Canon imageRUNNER 3030 Black and White...
All documents have dark vertical lines printed across them
you can change the drum unit. line will disappear after this replacing.
Apr 17, 2011 | Canon imageRUNNER 3030 Black and White...
My hp laserjet 3030 printer has gone offline for no reason. how do i get it back online so i can print documents?
You have not said what you've tried nor what PC you're using.
Turn printer off then on.
Open the printer folder, Win XP Start - Printers & Fax - Find the printer and right click on it, If "Use Offline" is checked, left click it to clear the check mark. Did thet help?
Nov 10, 2010 | HP LaserJet 3030 All-In-One Printer
I have and Canon iR3570 and when SNMP is disabled the printer goes offline and network printing ends. Enable SNMP and change the default community to something more secure and printer goes offline and...
It's possible that the SNMP Status Enabled box is checked on the print server (Printer/Properties/Ports/Port Settings). When you disabled SNMP or changed the community name on the printer, the server was no longer getting status updates and so flagged it as offline. Make sure the community names match.
Aug 31, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Hello, I am in Brazil, and my Canon ImageRUNNER C3220, is the problem of off alone, just off the digital display but not print anything when it is so, the technicians who were found not fix the problem,...
If the printer appears as offline in windows, consider disabling SNMP monitoring. Sometimes SNMP falsely tells windows that the printer is offline for events like "toner low, replacement not needed" and "low paper, drawer x"
Go into printers & faxes, right click on your printer and select properties, go to the ports tab, press configure port, un-check SNMP Status enabled.
Mar 03, 2009 | Canon imageRUNNER C3220 Printer
Oct 09, 2007 | Canon imageRUNNER 1023iF Black and White...
20 people viewed this question
old marine
old marine
