Can a Karr remote control with FCC ID elvat5h be configured to work with RS3000 alarm system?
Can a Karr remote control with FCC ID elvat5h be configured to work with a RS3000 alarm system installed on a Sienna 98?
  • 12 Answers
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
Posted on Jan 15, 2009
iamdev8it
SOURCE: sears remote keypad model clk1 fcc id hbw1579
http://www.lilocksmith.com/instructions/PDF_Files/LM_CLK1.pdf
Posted on Apr 12, 2009
  • 4 Answers
SOURCE: remote controls for factory alarm system are not working.
Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the passenger door module (PDM). • The PDM will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • The panic button should still operate normally when the system is out of synchronization. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the PDM, perform the following steps: 1. Stand within 1.5 meters (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds. The door locks should cycle in order to confirm resynchronization.
Posted on May 02, 2009
  • 87 Answers
SOURCE: I NEED PROGRAMING INSTRUCTIONS PLEASE!
Copy and paste or click - then program!
http://www.directed.com/guides/manuals/og/viper/429V.pdf
Posted on Jun 02, 2009
BeckiB_DISH
  • 286 Answers
SOURCE: Have LG/Goldstar CT14K40EX (Year 2000)
Hello! All that you need to do is follow the simple steps that I have provided below.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
520
654
678
If that does not work, try the steps for a power scan, which does not use any codes, it actually scans the codes on the TV for the correct one.
1. Hold down the Clear TV button until all lights at the top of the remote light up
2. Press the red TV POWER button
3. Press and release the up arrow on the remote about once a second until the tv turns off.
4. When it turns off, press the # (Pound) button
5. Try powering the tv on/off, and try the volume. If one or more of these functions do not work, start over at step 1 again.
Not all remotes program to all TVs, but I do hope that this helps you out!
Becki Barned
DISH Network Customer Service
Posted on Feb 23, 2011
Remote Control
the fcc is a red herring. (its just a fed. radio lic. to use this freq.)
what is your question?
you lost your 2nd fob that came new with car?????
want a new fob?
the toy, dealer parts list for this part, is on the toy site, you look and see it and see the p/n of the fob and then find one. (google p/n)
and get it programmmed.
http://www.programyourremote.com/classified/DisplayAd.asp?id=1230
all google hits, in 5 sec.flat
http://blog.keylessentryremotefob.com/2013/07/2006-toyota-camry-key-fob-remote.html
need more, google more.
be happy you dont need 2 fobs to get 3 on a jeep , like mine.
be vary happy. ($400 worth of freakn keys)\
Jan 29, 2014 | Toyota Camry Cars & Trucks
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
Will the excalibur touch remote work with another excalibur alarm i dont have the alarm model number but do have the alarm that i have on my car remote fcc # and it is a remote start alarm too the fcc...
The Touch remote can be used with any Echo compatible systems. These systems can be identified by their model numbers. Systems ending in E, EDP and EDPB are Echo compatible.
Dec 11, 2010 | Vehicle Parts & Accessories
Alarm is stuck in valet mode
This will work for many alarms, but not all:
Locate valet push button, may be hidden on or under dash somewhere. Turn on ignition, doesn't have to be started. Then push and hold valet button for a few seconds. Most alarms will chirp to confirm operation was a success.
DEI products require a slightly different procedure, and drivers door has to be open.
Some can be done through the remote.
Model of alarm will help alot, or FCC ID from back of remote. DC
Nov 04, 2009 | Vehicle Parts & Accessories
I need to know how to use my aftermarket remote alarm system FDCC ID M65TR5C. It came with a used 2003 nissan altima that I bought. It has the obvious ''lock and unlock'' buttons and an ''aux'' button...
The FCC ID you provided must be on the keychain remote. It appears that this was manufactured by Super Nova Co, LTD. Click the link below and enter M65 in the first box and TR5C in the next. This will give you access to owners manual, manufacturer data, and much more. To get more info you will need the fcc id or make and model from the main alarm unit.
Oct 18, 2009 | Vehicle Parts & Accessories
05 Dakota remote wont work
That happened to mine too. Is it a "Karr" remote? If so, it seems as if they use really cheap switches. I ended up de-soldering a working switch from the trunk release circuit and soldering it onto the alarm arm/disarm circuit. Works perfectly now. If you don't own a soldering iron, I recommend getting a new one or getting a better alarm system.
Jun 27, 2009 | 2005 Dodge Dakota
I bought a 2002 jeep wrangler with a Python vehicle security system, the owners guid was not in the car and I am wondering what all this remote will do. This is all I know about the remote: FCC ID:...
the lock button should arm the alarm, the unlock should dis arm the alarm. aux on this vehicle should not do anything and the red button should set off the alarm for panic button. You cang et a copy of the owners manual at Directed Electronics website
May 04, 2009 | Vehicle Parts & Accessories
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
