Question about Brother XL-2600
Treading sewing machine
How do you tread machine a Brother XL 2600 and how do you set it to sew thick materials?
These are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Posted on Oct 07, 2009
What is thread setting for sawing fabric with
I don't think you'll get it to feed on a domestic sewing machine, the foam is going to be too thick and difficult to feed through. I've used an industrial Singer 20U to sew vinyl to 1/4" foam which has a dacron layer glued to it, ie like carpet underlay thickness. This was to make replacement seat covers for ride on mowers; the Singer was strong enough to sew through both layers in a straight stitch, I could manage to overedge it on my domestic Elna but need a roller foot to stop the vinyl from sticking to the foot, and a leather needle. Even then, it wasn't easy.
Oct 10, 2013 | Brother XL-2600
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
My material is not feeding through the machine, how do i set it to feed. it works in the reverse mode, but not forward.
If when you sew in reverse you have big stitches then you will need a shop adjustment if you have made sure beforehand that you have the correct stitch length to sew forward.
Mar 07, 2010 | Brother XL-2600
When sewing with shirring elastic on bobbin the material does not gather the machine sews great any other time model no is bm-2600
my friend and i sat at the machine to see what was happening
the 1st thing wrong the plastic bobbin was the wrong size and the bobbin was not threading through the tension spring as the elastic was to thick
Jan 05, 2010 | Brother LS2020 Sewing Machine
I have a brother XL-2600, I have used many sewing machines and never had any problems with getting the tension right, but with this machine, the tension is never right. I have bought the best thread, I...
Sounds like you have tried everything possible, be sure you are using an anti static needle on the delicate fabrics, if that does not work it really does mean fiddling with the tensions until you get it dead right
Nov 06, 2009 | Brother XL-2600
Sewing machine XL 5500 settings
Your bobbin is probably too loose. When you set a new bobbin, stop every now and then and try with your fingers nail if it's nice and tight enough. Not extremely tight, but tight, not loose and moves easily when you set your finger between the threads.
With most fabrics (99%) the plate is fine at the the top position, just with very thick and "fragile" (satins etc) you might need to adjust it.
Settings: Tightest tension for the thinnest materials, more loose for the thicker ones, better have a test piece, it rarely goes under 5 anyway.
May 31, 2009 | Brother XL-5500 Mechanical Sewing Machine
Brother XL-2600 Logo
374 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
