Question about Drills
I recently acquired some drywall screwguns dewalt and hilti both are missing the depth control for guide where can I purchase these to make my screw gun whole
    Habit-Forming:
  • 195 Answers
Can probably get that part from www.ereplacementparts.com
Posted on May 16, 2014
2 Suggested Answers
FixYaSteve
  • 57 Answers
SOURCE: I am having difficult adjusting the Depth settin
Operator's manual is here.
To seat the screw deeper in the workpiece, you turn the adjustment collar to the right. To seat the screw higher in the workpiece, you turn the adjustment collar to the left.
If you've been using it a while and turning the collar is difficult, you've probably got some plaster dust, dirt, etc. built up in the threads for the collar. It's probably worth breaking that chuck and collar down, giving it a good scrub with an old toothbrush and putting some dry lube on it. I'm partial to Dupont's Multi-Use Teflon spray. It doesn't attract sawdust or dirt.
In the event you need it, exploded diagram with parts list is here.
If you don't want to mess with it, a Dewalt service center can clean your drill up for you pretty reasonably. I was in one in early June, 2010 and they had some 10% off service coupons sitting on the counter.
If this answer was helpful, please vote. Thanks!
Posted on Jun 14, 2010
A brand new Dewalt screwgun doesn't ...just doesn't do nothing
Well it's gonna have to be the switch then. Just for kicks and giggles see if you have continuity on both sides of the switch with the trigger pressed
Jan 12, 2016 | Dewalt Black & Decker u.s. Inc - Dw257...
I'm looking for a Hilti manual..Screwgun SD 4500
Hilti.com has parts breakdowns or if not it has a contact number for Hilti so you can call and get one.
Jan 11, 2014 | Hilti Drills
When using the drywall screwgun the drill bit comes out and sticks in the screw after every time I drive in a screw. Why doesn't the bit stay in place in the drill? Why does it come out and stick to...
Because the tip is brand new or you don't have a magnetic ti. Try tilting the gun a little sideways before you pull it away from the screw. Sorta like tilting a sweating glass a little bit before you lift it off of a coaster so that the coaster doesn't stick to the bottom of the glass.
Jim
Jul 26, 2011 | Bosch SG45 4500 Rpm Drywall Screwgun
How does the adjustable depth drywall bit work? The bit inside keeps spinning and does not drive screw into sheetrock?
It's not the tip, but the screw gun itself. The screw gun has a clutch on it that allows you to set the screw at different depths. You must adjust the screw gun to the desired depth. The deeper you want the screw to go, the less the clutch will slip.
Jim
Jan 03, 2010 | Dewalt Drywall Screw Setter 50 Pk Part No....
Adjusting the depth of a dewalt dry wall
you should just have to turn the collar, it is marked with which way to turn for deeper setting of the screws. You can go to Dewaltservicenet.com with your model number and download a copy of the owners manual for more specific information.
Jan 02, 2010 | Dewalt Drywall Screw Setter 50 Pk Part No....
How do i take off the chuck from my dewalt 18v xrp so i can use my hilti smd57 mag (drywall cont.' screw magazine) i unscrewed the screw down the shaft but now im stuck????
go to the tip section or under my profile in the section and there are detailed instructions on how to do this. Let me know if you still need more help.
Dec 20, 2009 | Dewalt DW056 18 Volt Cordless Impact...
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Bosch sg 45 drywall screw gun
You have to replace the entire depth guage assembly (the front plastic pieces where the bit driver is). Unfortunatly Bosch does not make the individual pieces for this gun. Any Bosch service center will be able to supply you with this piece
Apr 10, 2009 | Bosch SG45 4500 Rpm Drywall Screwgun
Drills Logo
53 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
