Question about RTO Hardware & Accessories
Model dt11 digital - RTO Hardware & Accessories
How do i find out what year my ford 2300 was made
The Model Design digit is the 3rd digit in the part number. It identifies the intended model for the part.It consists of mostly a letter but with some car models a number replaces the letter.
Most parts are designed for more then one model application. They are generic Model Design digits like A O or S. These generic digits make the part universal and/or specific to a body type.
Take this example, C8OE-9510-D is a 1968 Carburetor designed for 390 motor with Fairlane body type. But this was not designed exclusively for the Fairlane application alone as the carburetor was also used on Mustangs 390 and Cougars 390.
Oct 23, 2016 | Ford Cars & Trucks
Ineed a User Manual to learn how to operate Model # 75379 and or 5X300
Here is a link to this model from the Sakar Website for Model# 75379
Sakar Link
Jun 25, 2008 | Sakar 81480 Digital Camera
Where can I download copy for 1993 model
Model 1993 is not enough information to find a manual for your Digital Camera. What Brand? is 1993 the year or the model?
Actually, I couldn't find any 1993 model
You can do a google query
Input Manual Digital Camera The brand and the model
Or reformulate your queston so someone might find it for you.
Apr 28, 2015 | Cameras
I have anew orion tv model no.tv1934a an I was asking if it's a digital tv.because I have a antenna but I can't pick up channels?
This model is not digital.....to receive digital channels you need a digital set top box or another type of digital receiver to get any channels!
Feb 01, 2015 | Orion Televison & Video
DT11 timer turns on aplliance but will not shut it off.
1) DT11 is older timer, and may be may be copied by foreign manufacturers. Timer has 1 year limited warranty.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
2) Don't buy timers from ebay or local drug store.
Don't buy used timers.
3) DT11 timer may not be rated for appliances. Usually this type timer has rating for 600-1200 watt incandescent bulb, and will overheat and fail quickly with higher load, such as appliance load.
Buy Intermatic appliance timer for appliances:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
4) Always reset timer before programming.
5) Review programming for conflicts and overlaps that would cause timer not to function as expected.
Dec 16, 2012 | Hardware & Accessories
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
Is this model digital
You don't say which model or make the TV is and we are not mind readers at FixYa.
However most TV's made that are digital have on the menu somewhere digital and analogue, because they have two tunners. If you look at the set-up menu and don't see digital set-up or something like it, then chances are it's not digital. If not then the only way you can watch this TV is with the box you mention.
Feb 01, 2010 | Televison & Video
Is my Toshiba TV, model MW20FP1, digital?
I solved my problem by going to toshiba.com and found a list of models that ARE digital... mine is not on the list so I will get a converter box!
Dec 27, 2008 | Toshiba 27A44 27" TV
Hardware & Accessories Logo
32 people viewed this question
Top RTO Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
