Question about Watches
Geonaute watch instructions
Change from km to miles
2 Suggested Answers
SOURCE: I dont know how to change the time on my decathlon
I nearly went crazy pushing buttons, but finally got the right combination. From the normal Time Display (as you would normally use the watch, no need to push any buttons) Push and Hold for a few seconds the Lap/Reset Button. The "Set" Mode will become active. Release the Lap/Reset button when Set appears in the Display. Notice in the Display a small Arrow that points to a button, either the ST/STP or Mode Button. (Initially it will be the ST/STP Button). When you depress the button to which the arrow points, the Field Flashing in the display will be set (For ST/STP) or Changed to the next Field (When the Arrow Points to the Mode Button). Simply toggle through the fields (using the Mode Button) and set (using the ST/STP Button) as needed. You will also be offered the ability to set the Month, Date, Day, 12/24 HR, and a M-D (It stands for Month - Date, in Europe it's more common to display as Date - Month). I did not change this field since by default on my watch it displayed M - D first. The setting cycle will be finished off when you have set the various fields by again pushing the Lap/Reset Button. Not related to setting the watch, but possibly useful, the Watch will completely reset if all the buttons are pushed at the same time, including pushing the Display Light (or in the case of this watch, the illumination used for the Display Characters). Hope this helps, it worked for me.
Posted on Nov 06, 2011
How do I reset a Sportline WV1915WH after putting in a new battery
RESETTING PEDOMETER DATA
1.
Reset Pedometer data by
PRESSING & HOLDING
the
RESET
key in Step, Distance (Mile or
Km), Calorie (Kcal), Speed or Timer modes
Aug 29, 2017 | Sportline Watches
Where can I get instruction details for my POD 550 watch?
RCX5 found it surprisingly light and small. It doesn't look like a computer on your wrist like many other GPS watches. Of course that is largely because the bulk of the GPS components and battery are in an arm band.
The armband and separate GPS device seemed like, and became, one extra piece of equipment to worry about.
The watch, heart rate monitor and foot pod all use watch batteries. Battery removal can be difficult, however once the back is removed the batteries are easy to install and replace. The GPS piece is charged with a standard USB cable.
The speed and cadence sensors batteries are not replaceable. These sensors must be purchased again when they wear out
The speed and cadence sensors are attached to a bike with zip ties. I found them easier to install than the Garmin sensor largely because they are separate devices. It was easier to position each of them so that they picked up the magnet from the wheel/pedal separately, rather than trying to align one device to detect both.
Additionally the speed and cadence sensor each have a built in led light that flashes each pass of the magnet.
However, to configure your stride length is tricky at best. The best way to do it is to run a distance using the stride sensor that you know the actual distance of, then change the distance in the history. So let's say you ran 1 mile. The watch believes you ran 1.1 miles. By changing the history to 1 it should adjust the settings so that the next mile you run will record correctly.
Once you have been using the watch for some time you can get into advanced setup. You can add your own sports, or configure the devices, and screens setup with each sport.
You can do this from the watch, but it is easier to do it from the Polar Web Sync software. The software works much like a remote terminal for the watch. You connect to the watch and add or change each sport profile, or change user or device settings.
May 09, 2015 | Watches
HOW USE TACHYMETER & WHAT TACHYME3TER MEANS
A Tachymeter helps you estimate the speed you are going.
It uses the basic formula that speed = Distance/time
Here is how to use it: (For the full article see the link below)
To use tachymeter, simply start the chronograph or stopwatch when the object measured passing the starting line. When the object reaches the next mile or kilometer marker, stop the chronograph or stopwatch. The point on the tachymeter scale that adjacent to the second hand of the watch indicating the speed (in miles per hour or kilometers per hour) of object traveling between the two points.
For example, we want to measure the average speed of a vehicle is moving. Start the chronometer or stopwatch function when the car passes the starting line, and stop the timer after the vehicle traveled exactly 1 mile or 1 kilometer. Then look at where the chronometer hand (the second hand of the watch) is pointing to, and get the reading or value of the corresponding number at the tachymeter bezel or dial. Let's say the stopwatch stop at 3 o'clock position, meaning 15 seconds had elapsed for the car to travel 1 mile or 1 kilometer. At 3 o'clock position, the tachymetre value shows that number of 240, which means the average speed of the vehicle was 240 mph or km/h.
Source(s):
http://www.mydigitallife.info/2006/12/10...
Apr 02, 2013 | DKNY NY5045 Watch for Men
I dont know how to change the time on my decathlon geonaute watch
Nov 01, 2011 | Watches
How do i go from miles to km i am canadian we use km
Thank you for contacting FixYa.<br /> Unfortuntely you will have to contact Timex on this one, I dont know if that is an option they have. You can go to:<br /> http://www.timex.com/info/Product_Instruction_Guides_Downloads<br />or call their customer support, Sorry.
Aug 24, 2010 | Timex Ironman Triathlon 50 Lap Digital...
Cannot set Home Time on my watch
Go to their website "www.tech4o.com/downloads/manual_accelerator.pdf".
Full instructions are there. Yon can print out the manual if you feel a hard copy will help.
Jan 15, 2010 | Silva Accelerator Fitness Watch for Men
Changing from Km to miles for my default settings
Follow this link:
http://www8.garmin.com/manuals/Forerunner50_OwnersManual.pdf
Read the chapter TRAINING SETTINGS.
Rate, please.
Mar 28, 2009 | Garmin Forerunner 50
I just recieved a Fossil FS4249 chrono wrist watch. It has a tachometer with serated/knurled outside ring. The ring does not appear to turn. No mention of the use in the instruction booklet. Thanks, Jeff
On a chrono watch the the tachometer ring is fixed. The tachometer is used with the stop watch feature of the chrono. If you start the stop watch while travel a measured distance....say a mile...stop the stop watch at the end of the mile. The stop watch will indicate the amount os seconds...also the needle will point at the speed on the tacho. 45 seconds points to 80 mph.
Jul 25, 2008 | Fossil Watches
Instructions for ladies' Armitron 45/6974
From the instructions that came with the watch:
Press the button at the top left to get into time change mode, press on the bottom left button to move between seconds, hours, minutes, etc.
Press the top right button to change numbers; hold to move quickly.
Mar 10, 2008 | Bulova Watch
Watches Logo
16 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
