My lg f200l back key not working properly oftenly its not working already , reinstall soft ware and reset, its korean mobile
I suggest downloading "Handy Soft Keys" or similar from the Android Market place.
Handy Soft Keys Android Apps on Google Play
SOURCE: the soft ware i have
The manual can be found on the manufacturers site here:
http://www.lge.com/products/model/detail/U8180.jhtml
SOURCE: i have lgkp220 mobile.i want lg kp220 software
Hi!
You can download the LG KP 220 software (PC suite) from this link
Thanks
Rylee
SOURCE: I bought htc touch 2 T3320. mobile 7 month before.
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
I hope this will help in solving the problem.....
SOURCE: Monile Phone LG GU290f How do
Well actually if they're saved into the memory card, all you have to do is plug the memory in the computer via card reader. Then you can transfer the images. No need to download any software.
