Question about Toshiba Computers & Internet
Error code when creating recovery disc
Toshiba Satellite M305-S4910 error code 0E01B5-26-00037304 when creating second recovery disc
Smash it, lol, i hate some computers, by the way im just kidding i have no clue what to do!
Posted on Jun 23, 2009
Toshiba Satellite m305-s4910
remove the battery pack and power source. make sure nothing is plugged into the laptop. hold down on the power button for 30 seconds. then reinstall battery, plug the the adapter into a known live power source (the real reason for your problem) and power it up!
Jan 16, 2012 | Toshiba Satellite M305-S4826 Laptop
Every time I open my lop top it says one thing error f3-f200-0002 and error has occured.please press ok to turn off the computer no matter what I do it always come up to be the same
That's normally a problem when rebuilding the PC from the recovery media, but it could be a drive issue.
Try booting off your OS disc and doing a repair install. You may have to re-install the OS completely.
Jun 28, 2011 | Toshiba Satellite M305-S4815 Notebook
I need Toshiba Satellite L455D-S5976 (PSLY5U00Q01T) PC Notebook factory restore instruction
Hello there,
Newer Toshiba laptops usually have the ability to create recovery discs that will let you recover to "factory settings." Try this:
1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
5. When prompted enter the first blank DVD and select Ok
6. When prompted enter the second blank DVD and select Ok
I hope this helps. Thumbs up if you think so.
May 04, 2011 | Toshiba Satellite L455D-S5976 Notebook
How to reset the toshiba l30s lap top to factory set up without the set up cd?
There is no way to restore it towards factory settings without the restore disc on your model.
May 03, 2011 | Toshiba Satellite Pro L300 Notebook
Useing toshiba recovery media center to create a back up of the computer 1/4 of the way through error code: 020123-F1-00000000
Hi, I bought a new Toshiba L850 today, installed Windows 7 (64 bit) and immediately attempted to create recovery discs (on quality Imation DVDs). I got the error described above and googled this site.This error prevents you from creating recovery discs. I have contacted both Toshiba support and support for the franchise that I bought the computer at. On another site a user reported the same problem and also contacted Toshiba support - "The second technician I talked gave me 3 options: send in the computer at a shipping cost (about $25), take it to the place I bought it, or pay for recovery disks ($29.95)". I'll be taking this computer back - it looks like it's broken out of the box.
Dec 27, 2010 | Toshiba Satellite A215-S4747 Notebook
How do i reset the m305-s4910 to factory setting
Recovery
  • How to recover a Toshiba notebook with the HDD recovery procedure
  • http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
From CD
  • http://cdgenp01.csd.toshiba.com/content/support/downloads/PMA500339010_web.pdf
You may have a hidden partition on the harddrive - if so you can recovery from there - BUT - you should also be able to create some bootable recovery DVD or CDs from the hidden partition using the toshiba recover cd creator Two ways to get to the hidden partition on Toshiba
  • Press an hold the zero key and power on - this will enable the recovery menu
OR on later models
  • Tap F8 as it boots and then use repair computer - from menu
  • How to recover a Toshiba notebook with the HDD recovery procedure http://aps2.toshiba-tro.de/kb0/HTD9A02QI0000R01.htm
if not you can order replacement recovery cds
  • https://backupmedia.toshiba.eu/landing.aspx
Apr 10, 2010 | Toshiba Satellite M305-S4826 Laptop
I need recovery disc for Satellite A105-S4094
Toshiba laptops come with recovery disks utility built in. you can ether do it by accessing toshiba recovery disk creator. if you do not have access to your os then you have to contact toshiba support or find some one with same laptop and ask them to create recovery for you.
Nov 20, 2009 | Toshiba Satellite A105-S4094 Notebook
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Recovery Disc not working
Is that recovery disc created in ur machine or not...
Nov 30, 2008 | Toshiba Satellite L15-S104 Notebook
Sound drivers for Xp sp2
For specific models with different chipset drivers, you can get the sound driver & pretty much everything else on support.toshiba.com. If you can't connect to the Internet, "Tecra, Portege", & sometimes "Qosmio" models came with a built-in HDD recovery, meaning you need to create your recovery disk by running the "Recovery Disk Creator". An application to create your recovery disk. A shortcut is created on the desktop by default, if you cannot find it there, try looking at "C:\Program Files\Toshiba\Toshiba Recovery Disk Creator" & run the "exe" file, it should give you a menu to create one. After creating the disk, you can use that disc to install the drivers for all Toshiba pre-installed devices/softwares on that machine. For Satellite models, the disc should come with the laptop when you boughtt it. When you have the disc, just insert it inside of windows, it will give you options to install the driver & software for a specific toshiba device.
Hope this helps.
Jul 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
491 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
