Question about PSC FALCON 4420 W/OVERMOLD/TETHR/26 KEY/64/64MB/BATCH/STD LASER
Falcon 4420 is not connecting to the network
Falcon 4420 is connecting to the network, but it is not letting me access anything on it.
How to restart falcon 4420
Falcon 4410/4420(52 Key) - Press and hold the power button and insert a paper clip into the cold reset button below the Alt key
Jan 07, 2012 | Falcon 4420
Falcon 4420 scanners needs cmos battery replaced on the pc board. What is the part number the battery and how easy is it to replace?
dont know for sure but these are usually 3032 button style batteries, you can buy them at a local supermaket.
pop out or slide out once youve got the case open.
NB this is a very general solution, open the case first if breaking the warranty doesnt worry you.
Mar 17, 2010 | Falcon 4420
I have a 4420 falcon and it works only when the usb cable is connected to te computer in other words, the internet doesn't function when i disconnect it from the stand that has the cable connected to it....
I presume the PC you connect to has an internet connection. If so this is normal behaviour. When you connect to a PC via a USB cable and ActiveSync the connection is given an IP address via the host PC. If under the ActiveSync settings you are allowing the connected device to use the host PC's internet connection then the 4420 has access to the internet. simpuls.
To get a connection to the internet you would require a different connection, i.e. wireless.
You would also need a wireless access point or wireless router. Set the SSID and encryption on the wireless device and match it on the 4420.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Jan 17, 2010 | Falcon 4420
Can we upgrade our Falcon CE4.2 device to CE5.0
Yes....contact your rep. There is probably a cost to this. There is with every other manufacturer
Oct 29, 2009 | Datalogic Falcon 4420 Handheld Barcode...
Wireless connected but no traffic
Go to the control panel an click on network connections look to see if connected if it is, connected right click on the icon and click repair to renew your ip address. If this still doesn't work reset your modem look for a button in the rear and press for a few seconds and wait for all lights on the modem to come back and try to connect. If neither work call your Internet provider for support and I hope I've helped you.
Aug 13, 2009 | Falcon 4420
this sounds to be an issue with your software, it is not from any of the standard installed software, try and cold boot the unit and reinstall any required software
Jun 04, 2007 | Falcon 4420
PSC FALCON 4420 W/OVERMOLD/TETHR/26 KEY/64/64MB/BATCH/STD LASER Logo
52 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
