Question about Toshiba 2060 Copier
Close front cover single out program - Toshiba 2060 Copier
2 Suggested Answers
  • 4 Answers
SOURCE: close front cover
THERE IS A PROBLEM WITH ONE OF THE COVER SWITCHES. EVERY COVER HAS A SWITCH, ONE OF THEM MAYBE STUCK, BROKEN, OR MISSING. GOOD LUCK.
Posted on Apr 24, 2009
Close Front Cover For Toshiba E-studio 350
There are many possibles that can cause "Close Front Cover"
Check the front cover actuator, switch. If all covers, switches is working fine, probably power supply is faulty.
Dec 02, 2015 | Toshiba e-Studio 350 Copier
Why does my Blodgett conv oven not turning on when I close the door?
Check the door switch to see if it is making contact. It is located inside the front cover on right hand side, next to the chain sprocket.
Aug 30, 2014 | Blodgett DFG-100 Gas Single Oven
Opening the door after a wash
Turn program selector to "off". Turn selector to Drain or Spin. Press the start / pause. Wait until program ends. Open door.
OR
Press "start / pause" until the start / pause light flashes.
OR
First, unplug the machine and turn off the water supply. On the lower right of the front panel is a 6" / 15mm cover. Near the bottom of this cover is a small hole. Insert a piece of wire into this hole, and push in gently. While pushing, turn the cover clockwise, it will came off.
The door release is a narrow white plastic strip hanging down on the right; Pull down on this strip while pushing in on the door, the door lock will release.
Pl click if helped.
Mar 18, 2013 | Bosch Logixx WFT 2806 Front Load...
Samsung SCX-4300 paper jam
sir i have samsung scx 3201 printer but paper loading problem so plz solloved my problem
Oct 23, 2012 | Samsung SCX-4300 All-In-One Laser Printer
I have just replaced my imaging unit - now it wants me to replace/install waste toner bin
When the life span of the waste toner container has expired or it's full, the smart panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise your machine stops printing.
To replace it follow these instructions:
-Turn the machine off, then wait a few minutes for the machine to cool.
-Using the handle, completely open the front cover.
-Pull the waste toner container out of the machine using its handle.
-Remove the container's cap from the container, and use it to close the waste toner container opening. Do not tilt or turn over the container.
-Take a new waste toner container out of its package.
-Insert the new container into position and then push it to make sure that it is firmly seated in place.
-Close the front cover firmly. If the front cover is not completely closed, the machine will not operate. -Please make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front cover do not close.
-Turn the machine on.
Dec 17, 2010 | Samsung CLX-3175FN Printer
The lens cover does not open all the way. I have to use my fingernail to do it.
It is either bent or has grit and dirt in between the slides. Try using canned compressed air, such as you use to clean a computer keyboard with, to blow air between the slides. If that does not work, even though you will have to be very careful, while the lens cover is closed put a single drop of WD40 on the cover and spread it with a Qtip over the entire cover surface. Holding the camera, front facing down, try turning it on and off several times. If that frees the lens cover, turn the camera off and wipe the surface of the closed lens cover with a soft tissue to clean the WD40 from the surface. Make sure then that your lens is clean before using the camera. If the lens cover is bent, then none of this will work.
Mar 24, 2010 | Nikon Coolpix 775 Digital Camera
My hp pavillion dv9000's hinge broke. But I was able to use it after. Then I tried to close it..and it just shut off and it will not come on. I want to know what I can do to fi it
HP *had* issued service alert 08112101 which covers the left display hinge failure.
HP Notebook Left Display Hinge Program
HP Pavilion Notebook
model series affected: dv9000, dv9100, dv9200, dv9400.
This program recently ended on May 31, 2009, but HP may still allow for a grace period.
Otherwise, you'll need the following:
Display panel back panel enclosure (single lamp) 432957-001
Display hinge kit (single lamp) 432963-001
LCD bezel w/ webcam (single lamp) 432955-001
Trained pro's should be able to do this in about 20mins, there is partial lower case disassembly and complete LCD housing dis/re-assembly.
-Sy
Jun 04, 2009 | HP Pavilion dv9000t 17" Notebook Laptop PC
Close front cover
Jan 12, 2009 | Toshiba COPIERS E-STUDIO 520 Copier
Need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Nov 26, 2008 | Chamberlain 950CB Remote Control
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
18 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
