Question about Zebra ZT200 Series ZT230 - label printer - B/W - direct thermal
Problem whith rs232? - Zebra ZT200 Series ZT230 - label printer - B/W - direct thermal
How I can transfer my files from a Acterna 5100E OTDR to my laptop? It only has a standard internal flash drive and 9 pin output. I have the original software.
This devices interface is extremely old technology the 9 pin connector is most likely a rs232 serial interface . If your laptop has a 9 pin rs232 interface you may need a DTE to DCE adapter .
if you do not have this old rs232 port on your laptop I think this device a usb to null modem rs232 DB9 Serial DCS Adapter Cable with FTDI.
http://www.startech.com/au/Cards-Adapters/Serial-Cards-Adapters/USB-to-Null-Modem-RS232-DB9-Serial-Adapter-Cable-DCE-FTDI~ICUSB232FTN
https://en.wikipedia.org/wiki/Null_modem
from my reading of the manual a null modem may be needed
Nov 16, 2015 | Cell Phones
Why cant I get my computer to accept it
you might have to set up the serial port settings with speed (baud rate) number of stop bits, even or odd parity. suggest google how to set up serial port on whatever operating system you have. does the p.c even have an rs232 port may need a usb to rs232 adapter device.
Apr 20, 2015 | Honeywell MS5145 Eclipse with Codegate...
RS422 or RS232
As far as I know ALL Panasonic Toughbook
(which have a bult-in serial port)
the serial ports (DB9) are RS232.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jul 06, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Usb rs232 cable
The USB socket shouldn't need a driver for that. USB means Universal Serial Bus. So it will accept almost any device. If there is an issue, find the USB to RS232 web site and download a driver from there, if one is available.
Oct 25, 2013 | Toshiba Satellite Computers & Internet
I need a laptop with RS232 port. What model should I get?
RS232 is now not being fitted to laptops This has become old technology. If you have devices that require connecting via an RS232 There are USB cables that emulate the connections of an RS232 that can be set to a com port to fool the device that it has the rightr connection. Look on Ebay there are quite a few at various prices, most from Hong Kong. I have bought aqnd used them to connect my radio scanners and Scancat software to program Amateur radios quite succesfully, as well as to run my old HP A3 scanner
Please rate my help++++Thanks for using FIXYA
Jun 20, 2010 | Toshiba Satellite M35X-S149 Notebook
Pin diagram for psc 8-0065-56 RS232 cable
Hello friend,
Despite seeing his request the RS232 serial cable pinouts 8-0065-56 is old, I wonder if you got the pinout of this cable and could send me, I have a big problem to solve and need this pinout if I could help will be very grateful
Hug john son
Mar 05, 2010 | PSC VS1000 & VS1200 Accessories - P/N...
Hi I'm Kandy When I try and load a card stitch I keep getting the following error message: PCDWIN22 Caused a General Protection Fault in Module PCD_WIN.EXE at 0005:38F6. The software then shuts down. I...
I replaced my USB/Serial RS232 port adapter with a genuine RS232 serial port on the PC. THis solved the problem. Further reasearch on the net indicated that USB to RS232 - serial port converters do often have problems. I previously had not had a problem running on Windows XP and this is what alerted me to the possibility of the USB/RS232 port adapter as a possible reason for the "new" problem.
Oct 24, 2009 | PfaFF Creative 7570
Need Adapter
LS4000i does not work with USB or RS232. It is an undecoded (dumb) scanner you need a LS4004 to work with RS232 and special STI adaptor for anything other then 4006, 4007 and 4008. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Sep 21, 2009 | Symbol LS 4000i Handheld
I have an rs232 cable attached to kyrptview cable box via a usb adaptor.. Cant get my pc to see the box.. its a dell pentium 4 on windows xp.. any help pls
I assume the RS232 cable is going to a serial port? I think you should add a USB card to your system. The old async chips used to support RS232 ports are not fast enough to take USB info.
Mar 28, 2009 | Computers & Internet
What is the right rs232 cable to connect a Denon 3808CI reciever and a Phillips RFX9600 serial extender
OK LOOKING AT THE SPECS FOR THE EXTENDER YOU DO NOT NEED TO WORRY ABOUT THE SERIAL CONNECTIONS, WHEN USING THE SERIAL CONNECTIONS YOU NEED RS232 CODE STRINGS TO CONTROL THE DENON OR ANYOTHER DEVICE THROUGH THIS EXTENDER USING THE RS232 CONNECTIONS.
IT LOOKS LIKE YOU CONNECT AN I/R EMITTER FROM AN MINI JACK I/R CONTROL PORT ON THE BACK AND THE OTHER END TO THE I/R WINDOW ON THE DENON
Feb 27, 2008 | Denon AVR 3808Ci Receiver
Zebra ZT200 Series ZT230 - label printer - B/W - direct thermal Logo
14 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
