Question about NEAT Receipts Mobile Scanner
How to remove engine cover 2011 Rav4 ? - NEAT Receipts Mobile Scanner
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 71 Answers
Use a torques bit. Looks like a star pattern screwdriver.
Posted on May 16, 2014
When I turn off the car my oil and engine light comes on and stays on. It only goes off when the car is running.
It is how it must work. Nothing wrong with your vehicle. However, when you switch the car completely off and remove the key, the oil and engine lights must be off.
Mar 15, 2015 | 2011 Toyota RAV4
Passenger side power Murrow on 2011 Toyota Rev4
MIRROR , no reason given? , but yes, yes if you cant see screws
that means they are inside door.
yes,
the FSM COVERS ALL THAT,READ IT
http://www.helminc.com/helm/search_service_owner.asp?Style=helm&class_2=TOY
Jan 08, 2015 | 2011 Toyota RAV4
How to change passenger side mirror on 2011 Toyota Rev4. Do I have to remove door panel?
dont remove the door panel just the cover inside car where mirror is then will get to the mirror bolts/screws
Oct 20, 2014 | 2011 Toyota RAV4
Do I have to remove door panel to install side mirror ?
Yes, The panel needs to be removed. Here is a video of the )^ but your car is almost identical.
2006 rav4 mirror replacement
Hw to fix rav4 2011 4wd check light stays on after air filter was changed
some newer vehicles have different ways to reset...try turning ignition switch on and off a few times without cranking...or removing one battery cable for a few minutes...
Jul 23, 2014 | 2011 Toyota RAV4
I have toyota 2011 RAV4.and want to know how to install fog lamps and new wireing
This is a social web site,not an automotive
repair shop or tech line, with access to free info
On the fog lamp assy,I would crawl under a similar
vehicle & see if all you need to do is remove a cover
plate or drill some holes
On the wiring,I think the dealer parts dept will provide
some harness, that should plug in somewhere on yours
May 24, 2012 | 2011 Toyota RAV4
I need to replace rear tail light assembly on 2011 Toyota RAV4 how is easiest way to do this?
take out the side plastic cover (between back seat & the tail light)
and take out the smaller black cover. hope this helps you !
Dec 03, 2011 | 2011 Toyota RAV4
Timing belt replacement
Disconnect negative battery cable. Disconnect power
steering reservoir, and remove reservoir bracket.
Disconnect wire harness bracket for Data Link Conne
ctor No. 1. Remove generator and generator bracket.
Remove ABS actuator. Raise and support vehicle. Rem
ove right front wheel. Remove right engine
undercover. Remove power steering drive belt. Sligh
tly jack up engine and remove right engine mounting
insulator.
Remove spark plugs. Remove crankshaft pulley. . Remove right engine mounting bracket.
Remove No. 2 timing belt cover. . Temporarily install crankshaft pulley with pulle
y bolt. Set No.
1 cylinder to TDC on compression stroke. .
Loosen mounting bolt of No. 1 idler pulley and shif
t pulley toward left as far as it will go to reliev
e belt
tension. . Temporarily tighten idler pulley. Remove cranksh
aft pulley and No. 1 timing belt
cover.
If reusing timing belt, mark direction of rotation
on belt. Also place match marks on belt and camshaf
t
pulley. . Remove timing belt from engine.
NOTE:Always turn crankshaft clockwise.
Mar 18, 2010 | 1997 Toyota RAV4
Where is the oil pump on a rav4 2002? The oil pump needs to be replaced in my rav4 but i don't know where on the motor it is.
to acces to oil pump , remove valve cover, front engine cover and oil pan ,its engaged to crankshaft directly at front
Apr 18, 2009 | 2002 Toyota RAV4
NEAT Receipts Mobile Scanner Logo
49 people viewed this question
Top NEAT Office Equipment & Supplies Experts
Steve F
Are you a NEAT Office Equipment and Supply Expert? Answer questions, earn points and help others
