Question about Cell Phones
Ok so what can I do if my note pad turns on but does not show anything on the screen other than getting a new one please tell me how I can get it to work?
  • 790 Answers
If the notepad turns on and you do not see it post or display, you most likely have a bad screen or internal problems.
Posted on May 16, 2014
Extra screen shows up prior to unlocking the screen
Hi::
ur defalt phones codes is 12345 or 00000 u can use it
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jan 20, 2013 | Cell Phones
Every once in a while it starts to beeping and shows F1 on the screen. ljohnson1029@sbcglobal.net
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 26, 2010 | Ovens
My Nokia 7705 won't turn on, won't charge, won't do anything. I try to turn it on and a little black battery with a red "X" through it, but nothing else. I try to charge it, won't charge. I didn't drop it,...
Hi this is telling you the battery is the wrong type if you have never used that battery in that phone before or it is telling you the battery has got bad cells, the phone and charger are working as its giving you that warning its just cutting off to protect the phone from over heating.
all you need to do is take your phone to one of those independent phone shops and tell them you need a new battery and show them the battery that is in it and if you have never used the phone before say it could be the wrong battery or if the phone was working with that battery then just get the same one again.
once you have got a new battery the phone will be working and charge as normal.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Oct 08, 2010 | Nokia 7705 Cell Phone
Toshiba a45-s120 laptop mouse pad is frozen
“Hi let’s see if we can fix this problem”
I. “To “Enable” the Pointer Device using the Touch-Pad, go to, Control Panel, click (“Mouse) in the “Hardware and Sound” category; go to, “Device Settings” in the (Devices) block.
II. “Highlight”; the item you want to (enable) this being the “Pointer Device.” Click the (Enable) button, just below. Be sure to (Click) on the “Apply” button, and click OK.
III. You may need to “Update Drivers?” Click on “Hardware, click “Properties,” click, on Driver.” If the, Update Driver (block) is not “Grayed-out” click “Update Driver”, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware.
To setup the Internet Connection: To Start, go to the “Control Panel,” you want to open the “Internet Options” window. Click on the “Connections” block, click the “Setup” button, and follow all the instruction carefully. “Important! Always click “apply, ok, and restart the computer after making changes to the computer.”
"Did this solution help?"
Feb 01, 2010 | Toshiba Satellite A45-S120 Notebook
How do i change the disc brake pads on my vr commodore. no abs
FIRST OF ALL YOU NEED C - CLAMP AND 3/8 RATCHETT WRENCH. AND SOCKET SET.YOU WILL NEED A HAYNES REPAIR MANUAL IT HAS PHOTOS TO SHOW YOU HOW TO REMOVE BRAKE PADS.YOU NEED JACK STANDS AND A CAR JACK.THE REPAIR MANUAL WILL SHOW YOU WHERE TO PLACE YOU FACTORY CAR JACK.WHEN LIFTING VECHICLE.
Jan 25, 2010 | 2005 Nissan Altima
With my medion digital notebookproblems with the pen instead of writing left to right, it rights on the right to the bottom of the page on the right can you help please as well
What I think is happening is that the Note Pad, when connected to the PC, mimics the screen layout i.e. 16:9. I turn my Note Pad sideways to landscape mode, with the paper clip to the left. Then works OK
May 17, 2009 | Electronics - Others
Possible caliper problem on 07 G6 brakes; noise but pads ok
call the dealer where you bought the car from, tell them exactly what is happening, if the caliper is the problem it should be under base warranty, although the dealer may make you pay for the pads, they are a non warranty item, the rotor should be covered also if the caliper is the problem. get it in writing before any work is done. I would push for the pads to be covered since it was caused by the caliper. dont back down.
Dec 31, 2008 | 2007 Pontiac G6 GT Convertible
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
My rio nitrus will not show anything on the screen
Ok. You have reset your device, there is a reset hole next to the DC-in hole. Then if it still not working then you have to ask for a new lcd screen/ lcd screen module. That means the LCD of your MP3 Player isn't working anymore. Good Luck
Jun 18, 2007 | Rio Nitrus MP3 Player
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
