SOURCE: Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Drain is blocked - unplug the auxillary drain plug and check for clog.
