Question about Frigidaire Dryers
There is power timer is rnning start switch is working door switch is working dryer will not run. mod#fer231as.
  • 351 Answers
You need to replace the safety fuse
Posted on Jun 23, 2009
If I hold the start button on the dryer the timer will advance but the dryer does not do anything else. If I let the button go than the timer stops.... Ideas?
You are feeding power to the timer through the start switch. Under normal conditions the power would travel through a centrifugal switch on the motor if the motor was running. Now you have to find out why it doesn't run. Check the button on the door switch and make sure it is not broken off. If the door switch is bad, the dryer will think the door is open even while closed. Another possible problem is that some newer dryers have a belt sensing switch that will not let the dryer run if the belt breaks or comes off. If it is an electric dryer it could be a bad power cord for the 220 line or the house outlet. The motor only runs off 1/2 of the 220 line (110 volts.) If there is a bad outlet or power cord hookup on the half that feeds the motor it will not run. Hard to guess when not there.
Mar 02, 2015 | Kenmore Dryers
Whiripool dryer t mod leq9508 pro
Sounds like the wire going to the motor from the timer is open somewhere or the contacts in the timer is not making a connection. If you have a schematic you could see which wire feeds the motor and see if it has voltage coming out of the timer.
If it has voltage could be a wire or the start switch I see you said start sw works though. Hope this helps if I think of anything else I'll let you know.
Mar 05, 2014 | Whirlpool Dryers
My dryer will not start when I push down on the dial. There is power to the dryer. When I turn the dial on to the timer, I can here the ticking sound, so the timer is working, but it wont start when I...
Maytag Performa Mod.PYET244AYW wont start has power door switch good thermo protection good at element cant fin any fuses timer has 120v and selecter switch
Oct 14, 2010 | Maytag Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore 64902 Electric Dryer
Dryer wont start. starter switch is new and timer will run when the door is closed
HI. if the timer is running, and the wiring harness is in good condition, this will confirm motor failure. I would advise to test the operational value of the door switch as well but if the door switch is working, this will only lead to motor failure.
May 22, 2009 | Kenmore 73952 Gas Dryer
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore series 70 mod#110.62722100
check the door switch first if it is ok ..(doors not popping open) then the PTS (push to Start) switch is most likely bad as it wont hold in after it was pressed
Jan 25, 2008 | Dryers
Dryers Logo
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
