Why is it my washing machine works without load and not with load ?
My ifb washing machine top load is got error in timing display as number 4
If the error comes up as E:04, then that is an error code that the washing machine is overloaded.
Try this:
Remove the clothes from the washing machine.
Unplug the machine from the power receptacle for 1 hour.
After 1 hour, plug machine back in and run the machine without the clothes in it until it completes the cycle.
On the next load, do not load the machine with as many clothes.
Please reply to me if this works.
Thank you!
Jun 13, 2016 | IFB Washing Machines
My whirlpool front load keeps cycling without the water filling.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fabric sofner does not work
the problem is not with the sofner.put a dishwasher [tablet] into your machine and put on hottest wash also put two tablespoons of salt in aswell run machine without load run a secound time as before still at hottest.machine will become ok.Look at it this way clogged arteys in the system same thing.adrian
Mar 15, 2011 | Equator EZ 3612 CEE Front Load...
Front loader signals off without going through the spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | Frigidaire GLTF2940ES Front Load Washer
Hi my washing machine is working but it sletting out alot of water,i think i put a rug in,and the rubber bit at the back all came off and has blocked something,i e filter or sumthing?? i sthere anything...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Hotpoint Washing Machines
My GE prodigy washer won't spin. It drains without spinning
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Whirlpool AWM029 Front Load Washer
I have a Fisher and Paykel washing machine (excellence8 7.5) and i lost the lid of the machine while moving it. I was wanting to know where to find a spare lid and how to get it working without one in the...
to get machine to work without lid you need a magnet(med size) place it on the plactic hob righthand side towards front of machine ( where the lid closes against the machine) and it will operate untill you find a lid ...:)
Mar 01, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
