Question about Measuring Tools & Sensors
Ghaseel ul Malaika means? - Measuring Tools & Sensors
I have a whirlpool cabrio platinum and it will not spin the cloths out. it keep flashing ul no matter what i try to do?
Hello!
UL message means unbalanced load. Turn off washing machine, wait for door to open and remove half of the clothes. Then try again do make a spin. If it's still displays UL error shoul mean a loosen drive belt or worn carbon brushes on the washingh machine
Feb 26, 2018 | Whirlpool Washing Machines
What does the error code UL mean?
UL means UnLevel. To fix , open door of washer, and redistribute the clothing/laundry in the machine, and press start. It should start spinning again. Sometimes , if you have a overly heavy load of laundry above will not work. What I have done is, put my weight on the machine (upper body laying on the top) until the machine has extracted enough water so the machine will be balanced.
Dec 10, 2015 | Washing Machines
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Apr 24, 2015 | Frigidaire 24 in. FDB635RF Built-in...
Ul is displayed what does this mean
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Jun 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the message ul mean?
The UL code means a unbalanced load,sometimes it can as easy as leveling the washer,or a odd load such a towels all being on one side of tub and thinner less water retaining sheets being on the other side.
Gene
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
Jan 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Unlock my phone
Dear sir, How are you, I'm sending you some codes and I hope these codes will surely help you out.:)
Nokia Code & their function:
  • *3370# This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
  • #3370# Deactivate Enhanced Full Rate Codec (EFR)
  • *#4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
  • *#4720# With this Nokia code you can deactivate the Half Rate Codec
  • *#0000# Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
  • *#9999# Phones software version if *#0000# does not work
  • *#06# For checking the International Mobile Equipment Identity (IMEI Number)
  • #pw+1234567890+1# Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • #pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
  • *#147# This lets you know who called you last (Only vodofone)
  • *#1471# Last call (Only vodofone)
  • *#21# This phone code allows you to check the number that "All Calls" are diverted to
  • *#2640# Displays phone security code in use
  • *#30# Lets you see the private number
  • *#43# Allows you to check the "Call Waiting" status of your cell phone.
  • *#61# Allows you to check the number that "On No Reply" calls are diverted to
  • *#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
  • *#67# Allows you to check the number that "On Busy Calls" are diverted to
  • *#67705646# Phone code that removes operator logo on 3310 & 3330
  • *#73# Reset phone timers and game scores
  • *#746025625# Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
  • *#7760# Manufactures code
  • *#7780# Restore factory settings
  • *#8110# Software version for the nokia 8110
  • *#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
  • *#94870345123456789# Deactivate the PWM-Mem
  • **21*number# Turn on "All Calls" diverting to the phone number entered
  • **61*number# Turn on "No Reply" diverting to the phone number entered
  • **67*number# Turn on "On Busy" diverting to the phone number entered
    Good Luck. :)
Dec 16, 2009 | Motorola Mobility E770 Cellular Phone
What does the UL mean on my bravo washer.
It means unbalanced load. It causes the stub to knock against the wall and i fear it will tear up my machine. I don't know where atraild85 got his information,
Nov 28, 2009 | Maytag Bravos MTW6600T Top Load Washer
The time display section indicated a code UL instead of the time left on the washing cycle. What does this code mean
keep getting a ul code and machine barrel knocks back and forth in the washer on spin cycle until the ul comes up. Cannot get it to quit. What is the problem?
Thanks
Aug 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Measuring Tools & Sensors Logo
24 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
