Question about Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal
I have an insinkerator Badger 5 that is making a loud noise. I can see that there is a piece of white plastic wedged in there - probably a toothpick put in by mistake - I detached from sink and the object won't budge. How can I get it out? Don't have instructions anymore so not sure how it comes apart. Thanksk Helene
    Champion:
  • 225 Answers
Try taking a long screw drive and turn the unit backwards, if you can get it to move a little then try to unwedge the peice with long needle nose plyers,should work .
Posted on Jun 23, 2009
Garbage disposal makes loud noise, nothing stuck, blades turn freely
Bearings in the motor are worn enough to allow the grinder plate to rub against the side of the chamber.
Apr 10, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Badger insinkerator, 1/3 HP does not start. Please help...i try the red button and didn't work...the blades aren't rotating....
Use wood broomstick handle down into disposal.
Wedge broomstick against side of sink opening and rotate blades free.
Or use allen wrench on bottom of disposal to free cutter blade.
If blades rotate freely and disposal has power, and reset is not tripped or will not reset, then disposal is bad.
I wrote ez disposal replacement steps:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Sep 11, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My garbage disposal jammed, (Badger. 5) I noticed this when I turned on the until and just heard a hum but nothing spinning. I shut off the unit and got out my allen wrench and inserted in the bottom and...
Just put a wooden broom stick into garbage disposal.
Wedge the broomstick against the cutter disk.
And push or pull broom stick against sink opening so it frees the cutter disk.
Oct 31, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Garbage disposle makes a humming noise when turned on. InSinkErator Badger 5, 1/2 HP Garbage Disposal
Did you also hear any clattering sounds when it started? If so, it is rotating. If not then this hum is the motor in the lock rotor stage. Did you place garbage in it yet? Always run cool water in it when starting it.
May 29, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Makes loud noise when running,like something is jammed in it. How to open up and check?
make sure power is off .!!!!! either use small lfash lite to look around , or remove unit and turn sp side down and work it out ruber gasket is removable
Apr 19, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Attaching dishwasher drain hose.
Are you talking about the "barbed attachment" on the disposal? If so, simply use a screwdriver and hammer to knock it out. Make sure you reach into the disposal (through the sink) to get this piece of plastic out after. Good luck
Jan 10, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Hi. I had a piece of plastic fall down my insinkerator badger 5 and jam the motor. I manage to turn the motor with the allen key to free the piece, but it's still in there making a lot of noise and I'm...
Hi, Use a needle nose plier to get it out or take it down and dump it out...
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
Dec 19, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Insinkerator badger 5 doesnt turn on
Make sure that the fuse/breaker is not blown/tripped You could take a voltmeter and check for voltage at the unit. Hope this helps
Sep 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My Badger InSinkErator 1/3 hp has cloth stuck beneath blades. Does not turn. Can I fix?
peeling potatoes for Thanksgiving and now my disposal will not work. Yes, have tries reset button and not working. When it's plugged in it just makes this strange noise. Please help
Sep 23, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My insinkerator stopped working
Yes there is..... Your unit should have a wrench with it to rotate the inner blades by hand. It usually look like an allen wrench. You can see the socket that the wrench fits into by looking up into the bottom of the disposer, from under the sink. Insert the wrench and use it to work the blades forward and backwards. Remove the wrench, and try it electrically. It may take a few trys, but this will get it running again. Once it starts, pour a large container of water into the disposer with it running to help flush the sticking materials out. You can also flush ice and water through it after the water to further sweep it out.
Best regards, --W/D--
Aug 11, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Ace Hardware InSinkErator Badger 5, 1/2 HP Garbage Disposal Logo
489 people viewed this question
Top Ace Hardware Electrical Supplies Experts
handygirl911
handygirl911
Craig Butler
Craig Butler
Mike
Are you an Ace Hardware Electrical Supply Expert? Answer questions, earn points and help others
