Question about Samsung Refrigerators
How do I fix a window display that is flashing 26 E and 8 E?
I have a RFG296HD Samsung refrigerator. After a storm the other night the window display on the door is flashing 26 E and 8 E. The upper frig is still cooling and the lower freezer is still working. The upper ice maker is not working but the water still dispenses. How do I reset or fix my problem?
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 1073 Answers
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Posted on Apr 30, 2008
  • 330 Answers
SOURCE: GE TFX22CR Ice Dispenser inoperative
Check the ice maker see it is in the right position, maybe you can try pull out the ice maker and clean it and push it back, make sure the position is right.
Posted on Jul 21, 2008
  • 958 Answers
SOURCE: Kenmore refrigerator
hi fperry74,
please look at the back bottom part of the refigerator , if you could see a small condenser fan there. it might not be running or running very slow. correct that problem then.
that is why your panel is very hot because a condenser line passes thru that panel and if the fan is not running, then the temperature gets very hot.
the efficiency of the fridge is also affected.
i hope i was able to solve your problem.
pls rate me.
tnx
drcool
Posted on Jul 23, 2008
  • 247 Answers
SOURCE: kenmore refrigerator ice/water in door not working
welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
Jun 27, 2014 | Samsung RS267TDRS - 26 cu. ft. Side by...
Whirlpool 6th sense fridge freezer instructions
If you had a storm when this happened the refrigerator W10120821 Electronic Control very possibly took a surge and damaged the capacitors on this board. GSS26C4XXA00 Parts List I'm here should you want my assistance,Thanks, John Tripp Appliance 911
Feb 24, 2014 | Refrigerators
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Nov 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
We had a short power loss the other night and now the LED display panel has flashing I E, called Samsung they want to set up a service call. Is this serious and how can I get rid of this?
TURN POWER OFF AND UNPLUG UR OVEN..WAIT FOR A WHILE AND PLUG IT BACK IN AND SEE WHATS HAPPEND...MOST OF THE TIME ITS JUST A AUTOMATIC RESETTING INSIDE THE OVEN...
HOPE THIS WILL SOLVE THE PROBLEM..IF THE OVEN IS STILL UNDER WARRENTY..THEN GET SAMSUNG SERVICE AND GET IT FIXED...
Oct 18, 2013 | Samsung RF4287HARS French Door...
We have a Samsung RS265TDWP side by side refrigerator. After multiple power outages last night in storms, I discovered this morning the temp on the fridge is 53. I have tried unplugging to reset. Did...
Being a newer fridge I would look at the control board being faulty. They do not Handel porters surges very well and you may have blown a relay or resistor on the board. I would install a surge protector on anything you own with electronics in the future.
Sep 08, 2012 | Samsung SRS20DTD Side by Side Refrigerator
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
Konica 7020 error code f-26-2
Says that it is a PCL connector problem. Look at all of your connections and make sure they are ok.
Jun 24, 2010 | Office Equipment & Supplies
Power outage caused by fridge to quit
OUCH! , the partial digit display is an error code that has a meaning and they are never good , these units I have seen/repaired many times but I do not have the code book to determine it.
Try holding down the power freeze and power cool at the same time until you get something. If the unit is ok it will reset and hopefully be fine , if you still get a code these units have longer warranty's and could be repaired with no charge.
Phil
Apr 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
19 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
