Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
How do you stop water going into plastic tube running to the fridge?
2 Suggested Answers
Controlfrk
  • 304 Answers
SOURCE: Water leak from ice maker
The fill line internal to the freezer is likely frozen up from the elbow inward.. When the icemaker calls for fill...pressure builds up on the plastic tubing causing it to pop out of the elbow. Check the tube inside the freezer by removing icemaker and running a long thin screwdriver or a rigid wire up into the tube until you feel ice or the plastic elbow outside.
Clear ice, if present, by squeezing hot water in from freezer side with turkey baster until cleared and water comes out back.
Posted on Aug 22, 2009
Cu2026 not making much ice
Sometimes the water inlet gets clogged. This happens a lot if u are using well water. Take the water line loose from back of fridge. fold the tube to stop water from leaking on floor if it is a plastic tube. have a bucket handy and put line in bucket let the water flow. It should come hard and fast. If not go to water valve where it pirces the main water line. check the hole and make sure it is large enough to supply the water. I had to take a drill bit and make the hole a little larger. That fixed mine. If that is not the problem then I would replace water inlet valve on the fridge.
Mar 20, 2014 | Kitchen Appliances - Others
How do I change the plastic tubing that runs from the ice and water dispenser to the water inlet valve on a KitchenAid refrigerator Model #KSRG25FKWH03
Here is a video that may help you. YouTube also has quite a few other videos that pertain to this problem also. Give them a look.
Oct 15, 2012 | Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
G.e. tfx25jrba leaking water on the floor.
Mine leaked because the plastic tubing which leads onto your cold water pipes was old and cracked. There is a shut off for the water mine is in the basement off the cold water line if you shut that off till you can go buy a new line at home depot or wherever it will stop leaking. DO NOT shut off your water supply just look for where they tapped into the cold waterline for your fridge. Look at the back of your fridge and you will see a clear tubing from your fridge probably leading to your basement you will see the same tubing coming probably thru the ceramic floor thru to the basement leading to a valve if you shut that off till you can replace the tube it will stop just don't take the copper tap off because it has been screwed in there and made a hole in the piping to feed into your fridge. The piece is about $10.00 at home depot or lowes, a plumber is about $150.00 It is easy to do. Tell them you need a new assembly for your fridge, If this is an ice maker fridge as I suppose it is. If not pull out the fridge and see if you see a clear tubing
Feb 23, 2011 | GE Refrigerators
My Samsung RS253BAWW has been collecting water underneath the bottom drawer for some time now. It eventually winds up in the drip tray underneath and then runs out onto the floor. I've replaced the...
Depends if there is plastic tubing running inside fridge compartment. Shut off water to fridge. If that stops it you will have to look inside to see if there is visible plastic water tubing or if you can get to it from inside the fridge. Maybe the water line has a defect or got pinched and somehow split. Then turn on water, find leak and splice in a replacement section.
Jan 28, 2011 | Samsung RS2534 Side by Side Refrigerator
Where and how can I clean the drain hose on the Frigidare Ref. Water draining in Freezer Bottom
the drain hose runs from the bottom of the fzr to the tray under the fridge. The easiest point to access it is in the fridge compartment there will be a ketch basin (a plastic piece that ketches water from the freezer) with a plastic tube attached to it. This tube is what you want to clean I use compressed air on the tube and to blow up into fzr. good luck
Aug 16, 2010 | Refrigerators
DEFROSTING/ WATER RUNNING ONTO FLOOR & INSIDE FRIDGE
Check to see if the run-off tube at the back is plugged.
I dont know how old the fridge is - but if it a couple years old check at the back or the fridge - there should be a tube running down the back of the fridge down into the bottom tray. This tube funnels water from the freezer (condensation, or water from the defrost) down onto the tray holding the compressor where it evaporates with help from the heat off the compressor. Sometimes this tube can get plugged up with some scum or mineral deposits, causing the built up water to drain from inside the fridge.
The tube shouldn't be too hard to remove and clean out with some hot water and pipe cleaners. Had the same issue on on a GE fridge last year.
Hope this helps!
Dec 30, 2008 | Whirlpool ET0WSRXML Top Freezer...
How to replace water inlet tube running into bottom of fridge on fridge side from water valve.
get a plastic barb connector at lowes, or eq. inside the fridge side connect the end of the old tubing to the new tubing with the barb connector and pull the old line out from the back of the ref untill the new line comes out the rear of the machine to the water valve and reconnect tubing inside fridge
May 08, 2008 | Refrigerators
Fridge water "overflow" ?
It is supposed to drain to a plastic tray under the fridge. There is usually not a lot of water that drips down there... and the water usually will evaporate before overflowing.
If the water is draining on the inside of the fridge, then the drain tube on the rear of the fridge might be clogged. You should be able to remove the tube fairly easily, and then see if you can blow air into it to see if its clogged. Sometimes it just gets clogged with dirt and dust. If the tube is clogged, and you cannot blow air through it, then see if you can get a small somewhat flexible wire and push it through the tube.
Hopefully it will make it all the way to the other side.
Hope this helps.
Good luck.
Mac =)
Feb 11, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
16 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
