Question about Pentair Pool & Spa
The display will not show the temperatures between 80-89 degrees
  • 790 Answers
Faulty display modual
Posted on May 16, 2014
How to adjust oven controll to the right temp.
You may find that your new oven cooks differently than the one it replaced. Use your new oven for a few weeks to
become more familiar with it. If you still think your new oven is too hot or too cold, you can adjust the thermostat yourself.
Do not use thermometers, such as those found in grocery stores, to check the temperature setting of your oven.
These thermometers may vary 20-40 degrees.
NOTE: This adjustment will not affect the broiling or the self-cleaning temperatures. The adjustment will be retained
in memory after a power failure.
Adjust the oven thermostat-Do it yourself!
To Adjust the Thermostat
Touch the BAKEand BROIL HI/LOpads
at the same time for 2 seconds until
the display shows SF.
Touch the BAKEpad. A two digit
number shows in the display.
The oven temperature can be adjusted
up to (+) 35°F hotter or (-) 35°F
cooler. Touch the + pad to increase the
temperature in 1 degree increments.
Touch the - pad to decrease the
When you have made the adjustment,
touch the START/ON pad to go back to
the time of day display. Use your oven
as you would normally.
or self-cleaning temperatures. It will be retained
Dec 02, 2014 | Hotpoint RGB745 Gas Kitchen Range
Temperature fluctuates in bake setting. Temp on display does not match real oven temperature.
as long as your measured temperature is within 15-25 degrees of shown temp, then it should be ok. remember the temp in the oven will be different from top to bottom.
Dec 11, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
The heater will not kick on. It's a programable 7 day that reads 69 degrees and if I arrow up to 72 degrees, nothing happens
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Dec 23, 2010 | Honeywell CT3600 7 Day Electronic...
Air conditioner comes on briefly then stops. The temperature gage on the panel which shows outside temperature is inaccurate sometimes giving a display of -27 degrees.
Well the outside temperature gauge is generally not wired into the a/c. The internal temperature is more important but is not displayed as such. The 'internal' temperature sensor is used to regulate the a/c blending door and blower speed.
When did the cooling problem start?
Aug 10, 2010 | 2002 GMC Envoy
Air temp indicator only reads temps below 50 degrees
Ambient air temp sensor could be the cause. Normally located in front grille area.
Oct 06, 2017 | 2002 Chevrolet TrailBlazer
When this thermostat is in the HOLD position, which cancels the programmed feature, I set the temperature to 72 degrees and the furnace runs until that 72 degree temperature is obtained. Now the thermostat...
If you still have the instructions for the thermostat, then it will show you how to get into the menu and set the swing on the temps. I would try to explain off the top of my head, but its actually quite a bit off numbers to remember. Hope it helps somehow.
Dec 29, 2009 | Honeywell Focus 6300B 5-2 Days...
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Pool & Spa Logo
49 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
