Question about Pentair Pool & Spa
Pentair minimax nt temperature will not show between 80 and 89 degrees
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Sounds like bad temp sensor should ohm out at 78 ohms if not need new one
Posted on May 26, 2014
  • 22 Answers
SOURCE: i have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Posted on Dec 21, 2008
SOURCE: Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Posted on Jun 05, 2009
  • 128 Answers
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
Posted on Aug 30, 2009
  • 990 Answers
SOURCE: E04 comes on after fan purge cycle-Pentair minimax nt pool heater
This is a fan falure code. It can mean the fan has problems (not likley if the fan goes and isn't labored) You have a sensor in your exaust (probally not this if you don't get a good start) The culperet is probally in the negetive pressure sensor. This is a 2-3 inch disc with wires going to the controls and a rubber tube going to the fan. Pull the tube from the fan and make sure the fan fitting is clear (poke with a tooth pic) Be sure their are no kinks in the hose. If the heater is 4 years old the diaprahm could be bad in the pressure sensor. Check the other things first but this is probally your problem. Good luck, hope this helped.
Posted on Jan 26, 2010
  • 64 Answers
SOURCE: error code e04
If the fan was seized, it is likely bad, even if you freed it. If it doesn't sound the same, or is not as loud as it used to be, it is also most likely bad. If it doesn't move enough air to close the air pressure switch, then you will get an 04 fault, which is an air flow fault. HTH
Posted on May 24, 2010
Getting ERR message on my Pentair Minimax
make sure filters are clean then check to see if voltage on both sides of pressure switch if so check to see if voltage to ignitor if so ohm out ignitor should be about 78 ohm at 70 degrees if ok then see if safety circuit is ok then check to see if 24 volts to the gas valve brown wire and yellow wire
Jul 26, 2014 | Pentair Minimax NT Heater
Error codes
You have a bad thermistor. The heater thinks that water temp is over 114 degrees.
Aug 14, 2013 | Pentair Minimax NT Heater
My minimax nt only heats till 90 degrees. I set it up to 104 which is the highest and it only stays at 90 degrees. Everythig seems to be working well, no errors either. Please advice.
Either the thermostat board is defective, the temperature sensor is defective or not enough heat is being produced by the heater. . I recommend you call the Pentair technicalsupport at 800-693-0971 and they should be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 25, 2011 | Pentair Minimax NT Heater
Pentair Pool Heater reads HI
I am not sure if you have found the answer to your issue, or not, but just in case. The display showing HI means that the heater is "reading" the water temp at over 114 degrees.
This will go away if you change out the Thermister on the inlet manifold for the heater.
Jun 06, 2009 | Pentair Minimax NT Heater
May 29, 2009 | Pentair Minimax NT Heater
Pool & Spa Logo
56 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
