Question about Toys
Hyundai xg 350 latch on rear seat stuck
Rear seats fold down to allow more cargo space. Problem is that latch has become stuck and wont release to allow seat to fold forward
tommyboinow
  • 324 Answers
SOURCE: Volvo V70 rear seatbelt jammed
i know this sounds rough, but pull the seat belt with both hands as hard as you can, this will more than likely free the seat belt, some of the seat belt may have jammed in the gear inside the roller box.......
Posted on Nov 26, 2008
  • 462 Answers
SOURCE: Fold down rear seats
THE SEAT RELEASES ARE IN THE TRUNK IN THE AREA WHERE THE SPEAKERS ARE NEAR THE EDGE OF THE TRUNK OPENING.
Posted on May 25, 2009
SOURCE: my rear folding seats wont fold down
When you open the trunk, there should be a knob at the top right of the opening. Pull that and it will unlock the locking mechanism for the rear seats. I just recently figured that one out myself!
Posted on Jul 10, 2009
  • 136 Answers
SOURCE: '04 LR Freelander - rear seat belt tensioned/stuck
un bolt to remove tension, pull some of the belt out and rebolt.
Posted on Aug 14, 2009
SOURCE: Kia Sedona seat stuck
Got it, with the help and eyes of my wife. The rear latch releases as the seat back is lowered. This release is ALMOST seat back down (about 3 inches above the seat bottom). As the seat back lowers, apply constant lift on the rear latch, and it will release as the seat back lowers. Hard-won knowledge - I think I invented some bad words in the process.
Posted on Feb 26, 2010
Passanger side fold down rear seat will noy unlatch
Check from behind the seat to see that the lever actually moves the latch free. Usually it is like a cam locking on notches that hold the seatback up.
May 14, 2014 | 2008 Hyundai Azera
2005 gmc yukon third row latch #1 stuck
There is a cable that connects the handle to the latch, the cables like to break/stretch, sometimes if you look close at the rear of the seat where it attaches to the floor you can see the latch and manually release it with a long screw driver or similar tool.
Cables are avaiable from GM dealer if thats the problem.
Apr 04, 2014 | 2005 GMC Yukon Denali
Rear seat jammed release lever does not clear
Is this a fold-down rear seat? Is it jammed the the folded or open position? If folded, try putting some weight and pressure on the seat back while trying the release lever (having an 8-year old bounce on it would probably work well :-}). If it's jammed in the open position, have the same "assistant" bounce back and forth against the seat back while you attempt the release lever. If no 8-year old is readily available, have your spouse/significant other, friend (or enemy) perform the same actions as would the child. The latch may simply need some "persuasion". Good luck.
Sep 29, 2013 | 2007 Hyundai Santa Fe Limited
How do I life the rear seat to fold down the back of the seat?
will need to try and see if latch is damaged or debris is jammed in latch with the other side up look under at latch also check the cable --you can try kneeling on seat and bounce and pull on tab to try and get it to release
Jun 13, 2017 | 2004 Hyundai Santa Fe
I can't into my trunk there is something stuck therefore i need to fold down my rear seats and move it but i don't know how to fold them down I trie but i got nowhere
Be sure that your model has fold down rear seats...you should see the seperation around both rear seats...if equipped, the fold down release is located at the top corner of each rear seat...pull the lever up to release...if your model does not have the fold down option...you will need to remove the rear seat...remove the lower cushions first...look on the lower front of the seats for hold down bolts...second you will need to remove the top of the rear seat...hold down bolts are at the bottom of the top cushion...after removing the bolts (one each side) you need to push up on the cushion to remove...this will then allow access to the trunk...find the trunk latch and try to release by twisting the latch cable...Hope this helps...
Jan 20, 2011 | Pontiac Sunfire Cars & Trucks
My trunk is stuck shut, how can i get it open? they key will not turn and the latch thing by the front near the gas release will not work either...
If you have rear seats that fold down you can access the latch mechanism from the left side rear seat....if you are flexible. pull the corner of the seat forward to allow your arm to slide in behind. about 14-16" in, feeling up inside the trunk you can feel 3 quarter size holes in the sheet metal. The second hole has the cable release arm. stick your finger up there are pull towards you. this will release the seat allowing it to fold down. Crawl into the trunk. there is a glow in the dark release handle on the inside of the trunk lid to open the trunk.
Jun 29, 2010 | 2005 Toyota Corolla
I went to open my 2005 Toyota Corolla trunk using my car key. When I rotated the key, the mechanism went 90 degrees CCW but the trunk remained locked. I tried the trunk release in the car but it wouldn't...
If you have rear seats that fold down you can access the latch mechanism from the left side rear seat....if you are flexible. pull the corner of the seat forward to allow your arm to slide in behind. about 14-16" in, feeling up inside the trunk you can feel 3 quarter size holes in the sheet metal. The second hole has the cable release arm. stick your finger up there are pull towards you. this will release the seat allowing it to fold down. Crawl into the trunk. there is a glow in the dark release handle on the inside of the trunk lid to open the trunk. Note, these are instructions for an '04 corolla but I think it should work
Feb 15, 2010 | 2004 Toyota Corolla
WHERE CAN I FIND THE JACK IN MY 2004 SANTA FE GLS/LX?
most likely in the rear compartment on the side there should be a removable panel take it off to expose the jack
Oct 26, 2009 | 2004 Hyundai Santa Fe
Hai i would like to know how to fold the back car seat to increase cargo space in hyundai santa fe 2003
The rear seats have a pull strap located between the bottom cushion and the backrest of the rear seats used to disengage a lock to lift up the bottom cushion. The pull straps will only stick out an inch or so, or they might have fallen down between the seats and then you wont see them. Before you can lower the backrest of the rear seats, the bottom cushions have to be lifted up and forward out of the way so that the backrest may lie down flat. If your pull straps are not visible between the bottom cushion and the backrest, you may have to stick your hand between the cushions and feel for the straps. Once you find the straps, pull upward on the while lifting on the bottom cushion where the pull strap is located and the seat should tilt forward. Once you have manged to do this, the lever for the backrest is located on the top of the backrest. Just slide the lever and tilt the backrest to the desired position.
Apr 13, 2009 | 2003 Hyundai Santa Fe
Rear seat won't fold down (60 part of 60/40 seat)
I had the same problem on my '03. The seats would not fold down using the latch release as I had always done. So I tried a combination of pulling up on the side latch AND the top latch and the seat folded down. It really doesn't FIX the problem but circumvents offending  defective part. I will use this method until it doesn't work then I might shell out the $$$$$ to the dealer.
Jun 18, 2008 | 2003 Honda Pilot
Toys Logo
24 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
