Question about Kenmore Washing Machines
Kenmore 80 series washer. model #110.29812890. Water wont drain out. Wont spin either. Please help me. I'm so frustrated.
  • taddertalk
    taddertalk Jun 23, 2009
    Can u tell me the steps on how to change the lid switch. I took out the 2 screws but it wont pull out enough for me to see it. Can I actually lift the lid on the washer so I can get to the lid switch better?
  • 351 Answers
This would be a lid switch i carry them in stock and can ship out today yet... whirlpoolpartssurplus.com
Posted on Jun 23, 2009
  • Mark Nichols Jun 23, 2009
    yes, perhaps you could call my toll freee number and i can help you that way 866-798-4375
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
My kemnore 80 series washer machine wont spin or drain
Check in this order: belt, water pump, motor, drum shaft/bearing. Most of the parts will be either under the unit or inside. Most units require popping the top up in the front and removing the front panel.
Nov 11, 2012 | Kenmore Series 80 Creme Top Panel
The belt came off of the washing machine so it will not spin. We have a kenmore 80 series the model # 110.29852991. I just need to know where it goes back on please. A diagram if possible. Thanks
this unit does not have a belt,,this model number is for a direct drive washer,,,you have a coupling thats in between motor and transmisson..it looks like the picture enclosed..if we are talking about some other part ,,repost...onthejob5130_5.jpg
Sep 11, 2011 | Kenmore Washing Machines
Washer wont spin or take out the water
Hi 1st remove cabinet by removing 2 screws securing the console to the cabinet top.pry clips at corners and remove .you should now be able to pull cabinet towards you and separate it from chasis .motor /pump at center front bottom.plastic plug on right, wiggle that plug with washer in spin probably bad connection in plug.red/black wire Hope this helps please rate my solution. :)
Jun 26, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin in the spin cycle.Washer was full of water and making a buzzing noise.If you have any suggestions what it might be that would be great. Kenmore 80 series washer about 11 years old.
sounds like the lower bearing on the trans mission shaft is seizing up on you. had a frigedair that did the same thing. i took it apart to replace, but could not buy separate. it only came with a purchase of a new transmission,which ran $175- 275. so i junked it out. washer was only 5 years old.
May 29, 2009 | Kenmore Washing Machines
Kenmore 80 Series washer wont spin or drain at end of cycle
POST ME THE MODEL NUMBER. AND ALWAYS POST MODEL NUMBERS WHEN NEEDING ASSISTANCE PLEASE:)))
Apr 17, 2009 | Washing Machines
Kenmore 80 series washer not spinning/draining
The lid switch is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Washing Machines
Kenmore Series 80 wont do anything.
Check the coupling/transmission.
Jan 15, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
556 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
