Question about Kitchen Ranges
Kenmore gas range
I need to adjust my oven for lp gas.model #-3627331890, serial# 1S209728P
  • 4 more comments
  • stumpedagain Nov 04, 2007
    Thank you so much for your help. Just in time for thanksgiving..
  • Wayne Hawley Nov 16, 2008
    I take it from the discussion I have seen that Rangemeaster is part of the Kenmore group? We have just moved house and have a Rangemaster 110 Leisure running on LPG. The flames from all of the burners are yellow/orange (carburising) and leave a sooty deposit on the pans. It appears that each burner is the same, does this mean it has the wrong jets or is there an air register that requires adjusting to get the fuel/air mix right
  • bkalwicz Feb 10, 2009
    I purchased a fridgadaire gas range a few years ago when the house was being built. The house is equiped with propane I bought a cnverter kit and changed the top jets on the stove and reversed the port as required per the instructions. The top burners work fine the oven igniter heats up but does not ignite or gas is flowing. Whhat is the problem?
  • gilbertbrass Apr 12, 2009
    OK Done,ita all the way down. The flames are still the same. I turned it clock ways as if I was putting in a bolt with righ hand threads.
    OK Done,ita all the way down. The flames are still the same. I turned it clock ways as if I was putting in a bolt with righ hand threads. [ Problem- flames into oven and they are yellow.]
  • Anonymous Mar 12, 2014
    how do I adjust the my Kenmore oven temperature
  • 473 Answers
You need to turn the orifice on the safety valve down (clockwise) and this will make the flame smaller. The orifice is what the burner for the oven sits on at the bottom. The valve is # 214 on this diagram. Hope this helps.
Posted on Nov 04, 2007
How do you adjust the oven flames so they are not seen on the inside of the oven. Its propane
Posted on Apr 12, 2009
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ... > ... > Range > Whirlpool Range Parts
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
New kenmore gas range 790.7433 converted to lp and oven flames are way too high and produce lots of fix?
Do the rangetop burners act OK, Brenda? It's just the oven that's causing a problem?
Go back to the oven burner, right where you installed the new orifice. That orifice should fit inside an air mixture tube, probably stainless steel, leading to the burner itself. Right where the orifice fits into it will be some means of adjusting the air mixture - a sliding window of some sort, whether flat or round. You'll need to loosen the screw holding it in place (DO NOT remove the screw, only loosen it) and turn it so the air opening is larger. Right now you're getting too "rich" a mixture, too much propane & not enough air. Before you close it all up, try the oven again - see if your adjustment worked correctly. If not, adjust it again - this is a trial-and-error process, and it's different for every different altitude and climate.
At some setting, you'll get a nice blue flame with very little orange in it. If you live in a very high humidity area, you'll have much more orange color than people who live where it's very dry, but the flame should at least be MOSTLY blue, and should never be sooty.
Aug 01, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
I need to change from natural gas to propane serial # NF92903919
some ranges are adjusted on the unit, others you need to go to an appliance parts store and get them to order you a convervsion kit from ng to lp. the model you have given is incomplete i would need the rest to check this further for you. there should be a prefix ahead of the 468130 i.e. 110 - 468130??
Nov 08, 2009 | Kenmore 47153 Stainless Steel Dual Fuel...
Nervous about over tightening ... how tight before causing damage
You should contact the supplier of your oven as there may be a gas pressure reduction valve for the oven that requires adjusting. It needs to be done with a gas momoneter so not really any thing you should attempt your self.
Jun 11, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Need to change kenmore from Lp to Ng
Without a device to measure the pressure from the orifice you will have to adjust for the best flame on the burners (blue with no yellow) not going beyond the spreader plate.
Jun 04, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
have you tighen it down until it wont turn anymore this needs to be done on a LP gas model going from Natual gas
May 11, 2008 | GE JGBP40 Gas Kitchen Range
Kenmore Gas Range Oven not Working Properly
greg, sounds like your needle valve is not seated. Remove the bottom drawer. Look back to the base of the burner where the shutter air adjustment is. Right under there is the valve which should have a 1/2 inch or 7/16 nut. (I Forgot what size). Turn this nut clockwise until the flame is adjusted to the correct size, should be a nice blue flame. The nut maybe hard to turn because you are seating the needle. back
Dec 22, 2006 | Kenmore 78673 Gas Kitchen Range
Kitchen Ranges Logo
404 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
