Question about Dishwashers
Kitchenaid dishwasher w10193740a
My dishwasher has water spraying underneath (washer is not running). Assumed a busted supply line but it seems to be fine. Thought the supply fitting might need to be tightened but that didn't seem to help. Misty spray everywhere at bottom toward front of washer. Water dripping off hoses, wires etc. floor is soaked. Turned supply valve off to stop the water. Still can't determine source. Any thoughts? Washer is four or five years old, never had any problems before today.
myob247
  • 1342 Answers
SOURCE: Bosch Dishwasher SHU9925UC
Reset is probably a key combination, not sure which one though. Would have to refer to the manual. Unplugging it for a while should also reset it. With all the water cycling and overflowing some water may have gotten into an area of the dishwasher where it shouldn't have.
Here's a post
where the user had a problem that sounds a lot like yours. Read the last paragraph to see how they resolved it.
Here's another link for diagrams, manuals and how to guides for your unit.
Hope this helps. Let me know if I can be of further assistance.
Posted on Jul 20, 2008
  • 45 Answers
SOURCE: After I run the dishwasher, water stands at the
no it's not normal, you are probably having some cloge in the drain pipe, you could try with a pice of wire to pick it up or hose it down, or use some comercial unplaguners like mr. muscle or something like that, i think that this would do the trick
Posted on Oct 30, 2009
Testimonial: "Thank you very much for the prompt feedback! Yes, I will try your suggestion. Again, thanks."
  • 5603 Answers
SOURCE: water fills in bottom of washer when off
The fill valve has failed. You can get a rebuild kit for the valve.
Also clean the tiny straainer in the valve.
Posted on Dec 30, 2009
  • 112 Answers
SOURCE: No pressurized water spray
internal pump failure....check that it is not blocked ...the water supply hose only fills tank then the pump pust pressurised water to the spinning arms.
Posted on Jul 20, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: Our Kitchen Aid KDI -16
Sorry to read about your problem, I hope this helps you out.
yes it is, and yes it is... sounds like the water pump is leaking
I suggest you call a service company
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 21, 2010
No water is getting to my dishwasher to wash
I had a dish washer where the solenoid valves busted. It was an easy replacement visible at the front of this machine. Worth a look.
Dec 14, 2011 | KitchenAid Dishwashers
Kitchenaid dishwasher - small pieces of food are left on otherwise clean dishes. Water level comes to about 1 inch below heater coil. I ran it without dishes (or soap) and added about a quart of water so...
hello
contact the Help line
Call 1-800-334-6889
Major Appliances:
8 am - 8 pm EST (Mon - Fri)
Countertop Appliances:
10 am - 5 pm EST (Sat)
KitchenAid Experience® Store
1-888-886-8318
Thank You
Sep 11, 2008 | Dishwashers
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
Hello I have a Quiet Power 3 dishwasher that is leaving food residue on my dishes. The dishwasher is 2.5 years old and all of a sudden this problem is happening. I have not changed dishwasher soap. It...
If you live in a area with hard water, there may be a large buildup of hard water/soap scum in the bottom water reservoir where the pump, filter, and other working parts are. This is located inside the tub, not underneath. This scum/crystallized material can clog the water channels & filter so the water jets don't spray hard enough, as well as overwhelm the filter. Because phosphates were ordered removed from dishwasher detergents, hard water minerals can now react with the soap to create a heavy greasy-feeling scum. That scum can build up in the water lines, arms, bottom reservoir, and filter, providing an endless supply of goo to spray on your dishes. This can be fixed. You need to remove and clean out the spray arms, the filters, and especially the array of parts at the bottom of the tub. I've seen up to 1 cup of coagulated/crystallized scum in the bottom of dishwasher tubs (I know this may be beyond many homeowners, so if you aren't up to this first step, then just try the next/second step but do it 3 times with no dishes in the washer). Once you clean out the scum, then run the washer empty with a completely full detergent cup on the highest temperature setting, extra rinse. Before you start it add to the detergent cup 1 teaspoon of TSP(tri-sodium phosphate), a very powerful phosphate cleaner available at hardware stores. Your washer will now have all scum gone from the inner workings. From now on you must always fill both your detergent and pre-wash cups to the max and use a high temperature water setting, extra rinse. Chemically what you're trying to do is adding so much detergent that the scum-forming reaction is overwhelmed by the dispersant action of the detergent, and the extra heat helps this to be more effective. I am not a fan of vinegar in the wash cycle. Why? In some washers the vinegar fumes can reach the exposed contacts of the printed circuit board or touch pad, corrode them, and then your washer won't work at all, along with being very expensive to fix.
Nov 15, 2010 | GE Dishwashers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
Water left in bottom dishwasher and after resetting to wash will not start unless the water is drained out manually
GE Dishwashers are equipped with an anti-syphon ball that generally dislodges itself and goes into the drain line. To remove it, you'll have to pull it out of it's hole. Turn the supply off and open the kick plate. Remove the supply line from the dishwasher and the drain line free from the air gap. Remove the two screws that hold it to the counter top and pull it out. Remove the lower rack and spray arm. To remove the spary arm you have a 1/4 inch head screw to undo, and on the back of the spary arm is a plastic clip. Use a small screwdriver to depress from the spray arm and pull the spray arm off. There are then two 1/4 inch screws that hold the food screen on and remove the basket. Now, underneath the dishwasher is a large manilla-colored hose with a large hose clamp that must be loosened. Pull this loose and a bit of water as well as the ball will come out. Reattach and drop the ball into the left hole under the basket. Reconnect everything and slide the dishwasher back in. Reinstall drain hose and supply line. Turn on supply. Run and look for leaks.
Jul 11, 2009 | GE Dishwashers
Dishwasher not cleaning/water sprayers not spraying it appears
I had the same thing recently. Everything appeared fine mechanically, but no water would spray. I inspected the bottom arm as closely as possible and actually found a half melted clear plastic straw inside of it. 30 minutes, tweezers and a small pick eventually got it out and all is fine.
Sep 14, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Removing dishwasher
Washers have a fill line to a small blue valve underneath, there is also a power supply, and drain line hose. Make sure to turn breaker and water supply off, before removal
Jul 06, 2008 | GE Dishwashers
No water coming into dishwaser.
  1. Valve shut off to dishwasher
  2. Float stuck (bottom right front corner inside - check for obstructions)
  3. Kinked water supply line
Greg
Jan 02, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwasher pump will drain but not force water into spray arms
Hi there is a scond motor that forces the water through the spray arms it sounds like the motor has seized .
Dec 11, 2007 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Dishwashers Logo
37 people viewed this question
Top Dishwashers Experts
