Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Router bought new laptop and wireless router .put in router disc and started installing, got power light,wireless and link light to say router/laptop connected.but when it says it cannot get connected to phone line. but broadband is working ok.
  • 306 Answers
Re: router
Click start, control panel, internet options, connections tab, remove anything you see in the "dial up and vertual private network, click on LAN Settings, the only one that should be checked is "Automaticly detect settings, click ok and close all. open internet explorer if problem still there disable firewalls.
contact me if you still have issues.
Posted on Nov 10, 2007
0 characters
3 Points
It just stopped sending a signal and 5 hours later it started working then stopped when i tryed to lock it and now it wont work again all lights are on i reset it powered it back on prested the reset and...
The only computer I have is a Dell Insprion E1505 laptop and it is connected to a "COMCAST" cable modem. Windows XP, not Vista is installed. I purchased a LINKSYS WRT54G wireless router. I installed the setup disk and connected the modem to the router, and the router to the computer as step one, but when step two had me disconnect the router from the laptop so it could connect via wireless network, it just says "easylink advisor could not establish a wireless connection with the router
two laptops, a desktop PC and my son has Xbox live. I recently bought the Linksys wireless-g router with speed boost and that didn't work. If any of the laptops were on, the other wouldn't work and my son's Xbox live would lag. I was thinking about exchanging it for the Linsys wireless-N broadband router but then I read the reviews and they were horrible. I need something of that sort but something that isn't known for being unreliable and dying.
I bought the Turtle Beach X41 Headset, and it is causing some problems with my wireless connection. Due to a number of reasons, it is not possible to directly hook up my 360 to my modem. So, if I bought a new router that can operate on a 802.11a frequency, would that help or not? My current router is a Linksys Wireless G, 2.4GHz, router. Microsoft has said that an 802.11a frequency router could fix problems with other wireless electronics. If it would help, which router should I buy? I've read a few reviews for the Linksys WGA54AG 802.11a, and everyone says it doesn't work good. Any suggestions on another brand
i tink with these you can do some thing
Dec 19, 2010 | Linksys Wireless-G WRT54G Router
Router without disc
Normally, you can just plug it in and go. Most routers will allow connections with basic settings. IF you must have the easy-start disc, you can also get the program either online via download by searching on the manufacturer's website, or you can order the disc from the manufacturer.
You could also buy a new one, use the disc, then take it back to the store and say it's not "right for you". They'll return it and give you your money back.
Jun 27, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
I have just bought a belkin wireless router and it has an installation disc but i have no disc drive in my laptop
Download the software from the manufacturers laptop by connecting your laptop via an ethernet cable to your modem.Once downloaded then you have the software to install the driver.
Aug 27, 2009 | Belkin (F5D7230-4) Router (587009)
Connection problem for Laptop/Xbox 360
should start with the physical connection first. lets make sure you have a link light on both devices connected.
May 29, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Moving desktop across room where there is no cable connection.
you can buy a cheap USB wifi adapter and connect the desktop wirelessly just like your laptop, this should do the trick.
or you can buy an access point to extend the range of the wireless network, you should not be moving the router itself this way.
Feb 13, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
Netgeardg834g v3
find default gateway put into your web browser and log in
use rj45 cable to do this
any probs post it back here
Mar 20, 2008 | NetGear DG834G Router
Cant connect
Hi purplegarion,
hook up the router per instruction in manual and your particular internet connection.  With the Di524 powered up, use the end of a paperclip to depress the reset button located in a little hole beside the power connection.   open internet explorer and type in and press enter.  The password is admin. once th screen appears, click on Wizard.  Follow the wizards directions carefully.
For simplicity of security click on the wireless button while in the  wireless screen.  Set radio to on.  Enter a SSID like purplegarion. Set to open system.  Set Security to WEP.  Wep to HEX.  64bit.  Enter into Key one a 10 digit number you can remember like 1234567890.  Click apply.  Change your password to a personal password other than ADMIN.
Any device that attaches will need to enter the WEP 64 Bit hex Security key 1234567890, or whatever 10 digit number you put in the router.
Internet connection will require powering down you modem, and the DI-524 router.  power up the modem first and let it go through the start up, then power up thte DI 524.  you may need to make sure your DHCP is set to Automatically assign an IP address.
Oct 07, 2007 | D-Link AirPlus DI-524 Wireless Router
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
102 people viewed this question
Top SMC Routers Experts
Jose Cada
Jose Cada
Ali Reza
Level 1 Expert
Are you a SMC Router Expert? Answer questions, earn points and help others
