Question about Olympus XZ-1 Digital Camera
Why won't the olympus xz-1 charge - Olympus XZ-1 Digital Camera
Battery is not taking charge
More than likely your battery is bad.How old is the camera/battery? Rechargable batteries don't last forever. Suggestion: buy a new battery and see if that keeps a charge. Another thing to check is your cord. Make sure all connections are tight. However, there may be a wire breakdown in your cord depending upon how it's been stored.
Apr 01, 2014 | Olympus XZ-1 Digital Camera
My olympus camera won't charge properly
If the camera battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Olympus 228230 Model VG-140 Digital...
Zx-1 olympus camera
Do you mean XZ-1? If so, you may order a printed manual and/or download a PDF manual from here.
Sep 11, 2012 | Olympus Cameras
My Olympus Stylus 7030 won't focus and shuts off when I try to zoom.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 29, 2012 | Olympus Stylus 7030 Digital Camera
How do I change the photo setting from orf to jpeg
Page 41 in the instruction manual for your camera explains how to select jpeg mode.
In case you do not have the instruction manual for your camera I attached this link :
http://www.olympusamerica.com/files/oima_cckb/XZ-1_Instruction_Manual_EN.pdf
Regards
Sep 07, 2011 | Olympus XZ-1 Digital Camera
When I'm recording video using my Olympus xz-1, i keep encountering "card error". Often, it happen after recording for > 2 min. is this my memory card problem or the camera problem.
There is actually a very very big chance that it was the memory card. Your camera might have been having troubles writing data to the memory storage device such as the memcard itself due to corrupted files in it. Try to format the memory card to remove any sort of glitches, if it does the same, try a different memory card to see if it will do the same exact error.
Apr 10, 2011 | Olympus XZ-1 Digital Camera
Xz\xz\x?
the answer is 1
Mar 21, 2011 | Black & Decker Hammering
Calibration problems Zebra TLP 2844-Z
Your printing a 3 accross label, i think your ZPL command is wrong u must define the X and Y Coordinates of each field.
This is a sample of a ZPL command that i'd wrote. Im using a 1.5 x 1 inch. label
^XA ^PRC  ^LH0,0^FS ^LL203 ^MD0 ^MNN ^LH0,0^FS
(Design No. 1) ^BY2,3.0^FO40,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO64,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.2) ^BY2,3.0^FO344,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO368,136^AFN,45,13^CI0^FR^FDsample text^FS
(Design No.3) ^BY2,3.0^FO649,8^BCN,90,Y,N,N^FR^FD>:Barcode^FS ^FO673,136^AFN,45,13^CI0^FR^FDsample text^FS ^PQ1,0,0,N ^XZ ^FX End of job ^XA ^IDR:ID*.* ^XZ
I hope this will help you solve your problem...
Feb 26, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Olympus XD60 Microcassette
If the tape has ripped from the wheel itself then you can glue it back to the wheel with a good strong glue (I'd recommend araldite), or if the tape has ripped you can use sellotape to fasten the two sections back together.
I believe this cassette is moulded plastic so what you will need to do is carefully break it apart along the central seam to access and repair the tape itself, then use your strong glue to glue it back up after the repair is done. You have to be really careful dong this so as to not get glue inside the tape itself and gum up the mechanism.
Finally make sure you leave it to set properly before you try and play it (refer to the glue packet), for araldite I think its 24 hours. Also if you use glueto stick the tape back to the wheel make sure that is set before you reassemble the cassette or your wheel will get jammed.
Dec 02, 2007 | Olympus XZ90 Microcassette Tape (XZ-90, XZ...
Olympus XZ-1 Digital Camera Logo
32 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
