Question about Canon DR-4010C
My canon DR-4010C keep on blinking & don't feed & there goes an error message that says"Paper jammes in scanner; clear paper & continue but there's no paper inside
SOURCE: Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Posted on Jan 31, 2009
mohanchennai
  • 490 Answers
SOURCE: error message -4431
If the scanners keeps blinking while powering on, it is because it has not been intialised. Check for loose shreds of paper in the paper path. Unless the scanner intialises, it cannot scan. If simpel 'countonly' option works, then the scanner is okay.
S. Mohan, Chennai, India
Posted on Mar 18, 2009
  • 32 Answers
SOURCE: Canon DR-3080cii paperjam
The 3 paper sensors are located along the center of the paper path. They are: Registration (lever type) on the bottom between separation & registration. Look for lever damage or torn paper. Scan Start (reflective) on the top between registration & front reading roller. Clean the sensor window with qtip & alcohol. Delivery (lever) at the eject roller. Same as reg, but harder to see due to location.The feed roller exchange kit is 6915A001. The rollers in this machine are not considered user replaceable.
Posted on Apr 07, 2009
mohanchennai
  • 490 Answers
SOURCE: dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
Posted on Apr 17, 2009
hawaiianb283
  • 24 Answers
SOURCE: Error P00 on display, no paper jam found
It's going to be the sensor or the circuit board. Make sure the sensor is clear (use a vacuum cleaner with a crevice attachment blowing air should be very limited, because staples blown onto the circuit boards WILL fry them).
If the sensor is clear, then the sensor is probably unplugged; they don't go bad very often. If you don't feel comfortable taking it apart to check it out, call a tech. If you do take it apart, make sure the sensor and all cables are plugged in. If they are, you have a bad circuit board. For Canon Scanner Repair in Dallas, Texas :call Scan-R-Store
Posted on Feb 29, 2012
BROKE THE PAPER FEEDER
depends on if you broke it off or you really broke it apart. you can try using high strength sealant, or if you really broke it into two you can ask for parts if not online, at the nearest canon store
Oct 26, 2012 | Canon DR-4010C
Not Enough Memory Canon DR 4010C
There is no 'User memory' in Dr 4010C. The memory available is sued as a buffer for processing scanned images. You need to have 'memory' i.e., storage space in your harddisk. If you are scanning in Color, you need larger space.
Aug 29, 2011 | Canon DR-4010C
Our new Canon DR-4010C continually have double feeds or misfeeds. The rollers are new, so there is not any wear on them. Is there a fix for this frustrating situation?
Hi, you can check in scanner setting in last parameter ie in other there is one option detect by ultrasonic. if you have select tht option pls deselect it and check ones
Apr 07, 2011 | Canon DR-4010C
Jamms paper when copying
hi,make it clear where is the location paper jam?how to know follow this steps:-
1.make one copy & where the paper is stoped?
2.clean the area or clear misfed sheets.
May 14, 2009 | Canon Office Equipment & Supplies
Dr 5010c feeds one to five sheets, then stops
Apr 16, 2009 | Canon DR-5010C Scanner
P00 Error with no paper jam
See this link:
Look for reference to P00 error
http://74.125.47.132/search?q=cache:CSQKZT0GyBEJ:downloads.canon.com/cpr/software/scanners/5080QRG.pdf+DR-5080C+p00+error&hl=en&ct=clnk&cd=1&gl=us
Jan 23, 2009 | Canon DR 5080C Path-Through Scanner
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
Oct 09, 2008 | Canon DR-3080CII Path-Through Flatbed...
Error message -4431
Sep 04, 2008 | Canon DR-2580C Path-Through Scanner
Canon DR-4010C Logo
old marine
old marine
