Question about Garden Treasures 50-in L Painted Wood Patio Bench SXL-PB1205
Where can I get replacment wood for my bench - Garden Treasures 50-in L Painted Wood Patio Bench SXL-PB1205
Hello, I bought a two seater wood swing bench but it is squeaking - I don't know if the bolts are too loose or tight - would you be able to advise? Thanks Cassie
wood squeaks look for the squeak area and check the screws and bolts if its wood /wood problem put a couple of drops of cooking oil or if have a wood conditioner put some there
Jul 11, 2017 | Cars & Trucks
How do we we receive these missing parts: Wood hole covers. Supposed to have 8 (corner Bench)+4 (table)+2 (bench) = 14. We only received 4!
go back to K-mart and see the person in the lay-by section
talk with them and they will either refund the money or replace it with a new unit
You will need the receipt , the unit and all the bits that you have
if you still have the carton it came it , that makes it easier to carry
I have found most K-mart shops to be reasonable when there are problems with products
Mar 10, 2016 | Computers & Internet
HOW GOOD IS THE NEW HOLZMAN BENCH DRILL PRESS
The other practical alternative of Drill Woodworking is for drilling holes into wood, which is on occasion additionally stated a pedestal drill, pillar drill, or bench drill.
more details Best Drill Press 2018
Aug 02, 2013 | Drills
What is a walk-in picnic table?
A walk-inpicnic table has benches attached all around but there are gaps in the benchesto allow people to get in and out easily without having to climb over. Here isa link to one although there are cheaper ones available if you don't want toget it in wood. http://www.amazon.com/Cedar-Octagon-Walk-In-Picnic-Table/dp/B001PKZF2C
Jul 25, 2012 | Furniture
Are metal outdoor benches as comfortable as the wooden benches? They look extremely uncomfortable
It does just depend on the type you are getting.Metal benches can be very comfortable and even more than wood benches, dependson the angle and their cushioning. I suggest that you will try some benchesbefore buying. I can tell you that the metal ones will last longer and areeasier to maintain.
May 29, 2012 | Furniture
I want to get a wooden outdoor bench, but what about weather damages overtime?
If you prefer wood, then you should definitely go for the long lasting woods like Eucalyptus, cedar and teak. If you like metal benches, make sure they are painted in water resistant color and that they are also rust resistant.
Clean old wood
I would start by wiping It down with a damp cloth and then letting it try. Depending on its condition there are a few steps to take from here. One option for something in good shape would be a wood polish (though I don't think this is what you want for a work bench). If it needs more work, it can be sanded a fine grain sandpaper and then left as is, or stained or sealed. Just as a heads up, wood is very porous so if it is stained because something was spilled and left to sit, it's likely permanent. A dark stain (found at any hardware store) and some sanding might be able to over it up.
Mar 02, 2012 | Cell Phones
I painted a picnic bench with latex, and it peeled. I scraped off some of it, and much is left on. Is oil base paint over this a good solution?
Hi there. Try to remove as much of the old paint as possible. You should sand down the wood and paint a little bit to rough up the wood and only then paint over it. Paint sticks much better to roughed up wood. Oil based paint would also be a better solution. The best solution is to use stain, if that's an option. Alex
Jul 13, 2011 | Garden
Bench grinder starts but don't move
It sounds like the motor is burnt out. If the case can be opened, unplug it and check around for signs of too much heat, especially at any wire connections. You may be able to resolder or replace a wire to fix it
Mar 03, 2011 | Grinders
My Makita bench grinder has four holes to change the grinding wheel..how to I get the retaining nut off as I don't have a tool to fit the four holes?
Make your own wrench out of a piece of wood stock,with 2 screws or nails spaced out to 2 opposing holes in the retaining ring/nut.HarborFreight sells a 'spanning wrench' online .
Jun 30, 2010 | Makita Nip 5"(127mm) Bench Grinder Wheel...
Garden Treasures 50-in L Painted Wood Patio Bench SXL-PB1205 Logo
494 people viewed this question
Top Garden Treasures Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Garden Treasures Furniture Expert? Answer questions, earn points and help others
