Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Craftsman, 18 hp Kohler, 44" deck I am looking for information for belt replacement. The belt that engages the deck keeps coming off the pullys. I am assuming the the belt is old and is streched out. The belt appears old. Maybe there are some other items I should check??
  • 284 Answers
Try looking on the flat part of the belt for numbers go to napa auto parts and they will cross reference it or measure it.
or go to sears.com and enter the model # from your mower after you click on parts direct at sears site and find your belt #
or check all your pulleys with the belt off to be sure they turn free.( except pto )
be sure the belt guards are adjusted as close to the pulleys as possible with out hitting the belt when belt is engaged for the blades to turn
Posted on Jun 24, 2009
Craftsman dlt2000 20 hp kohler runs great until i try to engage blades pull up on the switch to engage and motor bogs and stalls
Now is a great time to remove the deck and sharpen the blades! In the process, you will find your problem. Look for clogs, seized bearings, freely rotating belts, etc... The problem is in the deck or drive belt. Hope this helps!
Sep 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
First, my tractor eats secondary deck belts like candy. It has become worse recently. The dealer told me to make sure the kids did not have the throttle at full while engaging/disengaging the PTO and...
Looks like your mowers have a little age on them. I recommend that you remove the decks for inspection. I bought one recently that the deck was rusted out in the middle causing it to flex and throw the belt. Check for good alignment all around and make sure that the blade guides around the pulleys are as they should be. If not that will cause them to eat the belt. Make sure everything moves as it should including the blade engagement mechanisms.
I hope this helps you get going.
Aug 06, 2011 | Husqvarna Garden
44" v-belt needs to be replaced
Look under footrest for diagram on sticker.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Instructions for replacing deck belt for craftsman2 12.5 hp riding lawn mower
when engaging my blades on my craftsman lt4000 12.5 hp lawn mower the pullys wont engage them
Apr 17, 2010 | Craftsman Garden
I am putting a new belt on my deck, model 917.258540, i see how the braker for the mower pully will tighten when i engage the clutch, but after i disengage there is nothing pulling the bar back into a...
the brakers on the pulleys should go against the pulley when disengaged & if you do one side at a time you can put deck back under yourself if i can further help e-mail me wade at wadembly@aol.com
Jun 25, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Missing springs on deck pullies need diagram of deck for springs
Go to www.managemyhome.com and download the owners manual.
After that I would go to www.searspartsdirect.com and look at the pictures of your mower deck (again you need the model #). Once you figure out what you  need then all you have to do is order then from sears.
May 20, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 18.5 riding mower when I engage the blades to cut the blades turn But they do not engage NO Power.Blades Turn But Not enough to cutthe grass.
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
325 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
