What does ec
What do the letters EC mean and how to fix
TOM2-TOM2
  • 110 Answers
SOURCE: can someone tell me the values of the capacitors ?
EC18, EC19, EC20 are 1000uf/16v 105c
never had to replace EC9 and EC10 but should by the same value look at the size if the same as EC18 - EC20 I would go with the same value. It should be printed on the caps. If that did not fix your dead unit replace the power supply board and same time.
Check for the parts here:
http://www.mcmelectronics.com
# NOTE - If this info was helpful to anyone please click on yes!
Posted on Jun 23, 2009
projdoc
  • 2237 Answers
SOURCE: sharp ec-14twt6 won't start
if the motor spindle spins easily when turned by hand, the motor brushes need replacing. if it doesn't, either something is stuck in the turbine, or the motor is siezed. if the motor is siezed, it needs to be replaced.
Posted on Jul 22, 2009
SOURCE: CERAMIC HOB EC 60 T. LETTER L NEXT TO CONTROL BUTTONS
Hi i had the same problem the L means Locked after lots of combinations of button pressing it is the - button in the middle and the 4th RING front right togeather that will unlock it took a couple of goes so persevere
Posted on Jan 02, 2010
SOURCE: ready for ec/kbc update. please the ec/kbc update
download ready for ec/kbc update. please the ec/kbc update
Posted on Oct 02, 2010
mrninja
  • 600 Answers
SOURCE: My keyboard types two letters
Change the settings.. Go to START>CONTROL PANEL>KEYBOARD and adjust the repeat delay (you can check it right there in a box)
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this.
Posted on Dec 29, 2010
What is the function of ec in midea
EC stands for Energy Compliant. It means the stand-by automaticaly when reaches the setpoint. Try with a different setting.
Sep 10, 2017 | Midea Heating & Cooling
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Aug 28, 2014 | Frigidaire Heating & Cooling
What does ec mean on my hot tub
EC stands for Economy mode. This is a setting that tells the computer to check the temperature of the spa less frquently, as well as running fewer filter cycles. Spas should be set to EC while you are away on vacation or not planning to use it for a while
Apr 29, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
What does Ec mean on the control panel
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Dec 08, 2009 | Balboa Instruments Garden
When i type certain letters the wrong ones work example p# ec ec o.
Your keyboard could be going bad.
One thing to try is go into the device manager and uninstall the keyboard and let the computer find it again on restart.
Nov 12, 2009 | Dell Dimension 2400 PC Desktop
Apr 15, 2009 | Kitchen Ranges
Passing PCL code from Word document
All PCL Command Sequences begin with the escape character (an ASCII control code with a hex value of 1Bh, 27 decimal) and end with the first upper case letter (or "=" note: "@" is considered an uppercase letter). In between there is either nothing (the PCL command is just the escape and a single upper case letter) or a set of one or two characters and often a numerical value. The single character commands are listed at the end of the "Decoded PCL commands" table below. The first non-uppercase character after the escape will be a symbol between "!" and "\" (most commonly one of %,&,( or *) which is called the "parameter." After the parameter there is normally a lower case letter called the "group." After this there may be a numeric value. If no value is present, the value is assumed to be zero. Finally the ending uppercase letter is called the "command." See Examples, Tutorials below for some samples of PCL commands and the Decoded commands List for detailed information. Note that these use the text "Ec" to mean the escape character. Since the escape character is not printable, it is very hard to convey in human readable text. Common abreviations are Esc, Ec, [], or <-. See the ASCII page for more information on the codes. That page also allows you to convert between hex, decimal or ASCII codes. The form below can be used to find english descriptions of PCL commands. Just paste the PCL into the box, if you use "Ec" or "esc" to mean the escape character, press the "Ec and esc
i hope this will work for you
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 12, 2008 | Computers & Internet
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
