Question about Viking Cooktops
Tytronics Part number pa020047 same as ri120e4 re igniter ?
I have a cvg4380 and I need to replace the igniters , how do you remove and replace the igniters
The link below shows the different parts for that unit. There is a button under the items that says watch video.
http://www.appliancepartspros.com/search.aspx?model=cvg4380
Feb 18, 2017 | Jenn-Air Cooktops
Maytag MGR7775WS igniter does not work
time for a new igniter, you can order it at marcone.com All you need is a model number
Oct 17, 2012 | Maytag MGR7775WS 30" Self Cleaning...
Bosch five ring hob ignition
It can be for another model if this is the ignition unit. Please confirm with your supplier before it can be tired as they might allow you to exchange if this order was misplaced. Please quote the part number or model of the oven.
Nov 11, 2011 | Cooktops
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
Jun 02, 2011 | GE Cooktops
One of the burners ignition will not turn off - it continually is sparking - i have to turn off the elec supply to stop the ignition ? any ideas
Hi and welcome to FixYa, I am Kelly. On the burner your having problems with the ignition control switch located in front of the gas control vale on the stem has failed. These are cheesy little switches that are thin ceramic with nothing but 2 strips of copper inside them. One piece is fixed and the other piece is movable by the ceramic switch cam. If the movable copper arm or fixed copper strip gets bent the ignition will not shut off. Also if the ceramic cam of the switch fractures it will cause the switch to stay actuated. The gas valve has to be disconnected and removed to change the switch on most units. The wires in the switch have to be unlocked by inserting a jewelers screwdriver into the holes in the switch body to release the wires. These switches are common to most every gas cook top models no matter the brand. Without your model number I can not provide you with the manufacturers replacement part number. Change the burner ignition switch on the front of the gas valve for the burner with the problem and it will work fine.
Thanks for choosing FixYa,
Kelly
Mar 05, 2011 | Cooktops
Clicks but does not ignite. works with match or lighter.
You will need to change the Igniter. There are at least 2 igniters that operate with one knob. Some units all 4 igniters operate with one knob. The clicking you hear is the other Igniter or Igniters clicking. The Igniter for the burner that does not light has failed.
The model number you passed is missing some numbers JGP628 should be like this JGP628BEC1BB or this JGP628WEK1WW
The Igniters are NOT all the same:
AP 3191250
http://www.appliancepartspros.com/part_details.aspx?part_id=3191250&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d214810%26diagram_id%3d21784824
or...
AP3779012 (No image)
http://www.appliancepartspros.com/part_details.aspx?part_id=3779012&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d5213362
It can even be a wire to the electrode / igniter that has found a chassis ground inside the cooktop.
When you have a complete model number go to this page and choose your model number:
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JGP628
The item you may need is item 154 of the cooktop.
Thanks for using FixYa!
Kelly
Mar 08, 2010 | GE 36 in. JGP628 Gas Cooktop
Smeg gas hob ignition
There is a problem with the board. It has malfunctioned onto an ignition mode. By switching it off, it shows the capacitor is holding chage untill flat.(Hence the continual sparking) Replace it.
Sep 20, 2009 | Cooktops
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Viking professional 30 inch, sparking problem
If you have replaced the spark module with the new, blue PA020041 Tytronics 0+4 spark module, the physical positions of the leads that go to the burner igniters are reversed compared to the positions on the old, white module. Make sure that the switch wire for the burner and the position of the spark wire both go to the same burner! The positions are marked on the white label with green lettering.
Nov 25, 2008 | Viking 31 in. VGSU101 Gas Cooktop
Switch assembly
See www.whirlpoolparts.ca/parts and enter in the model number. You will seea 10 page parts repair list including switch and ignition assemblies. Good luck
Aug 06, 2008 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Cooktops Logo
116 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
