Question about 1999 to 2012 Ford F350 Truck Super Duty Power Window Regulator with
Motorized rear view window fuse - 1999 to 2012 Ford F350 Truck Super Duty Power Window Regulator with
    Sergeant:
    Champion:
  • 242 Answers
Fuse should be by dash panel on drivers side check oweners manul for witch fuse it is
Posted on Oct 10, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Power windows wont roll up or down on 2006 Cadlliac cts
With the electronic's involved ,your best bet would be to take to a qualified repair shop . The door 's have electronic control module inside that control door lock's an window operation . Hooking up a professional or factory scan tool an viewing input data an checking DTC'S - diagnostic trouble code's would be the first step any professional technician would do . You probably have no idea what these are ? Messing with these systems can render your vehicle unuseable if you do not know what you are messing with .
Power Windows System Components
The following components are used to control the power windows:
• Driver door module (DDM)
• Passenger front door module (PDM)
• LH rear door module (LRDM)
• RH rear door module (RRDM)
• Driver door switch assembly (DDSA)
• RH front power window switch
• LH rear power window switch
• RH rear power window switch
• LH front power window motor
• RH front power window motor
• LH rear power window motor
• RH rear power window motor
• Class 2 serial data link
• DR MOD PWR C/B 30 Amp circuit breaker
• DRIVER DR MOD 10 Amp fuse -- DDSA and DDM logic, DDM internal driver operation.
• PSGR DR MOD 10 Amp fuse -- PDM logic and internal driver operation.
• REAR DR MOD 15 Amp fuse -- LRDM and RRDM logic and internal driver operation.
Power Windows Operation
The vehicle is equipped with power windows controlled by the door modules. Each passenger door window can be operated, either from a power window switch built into the driver door switch assembly (DDSA) , or, from a power window switch mounted locally on its associated door. The driver door window can be operated only from the driver door power window switch built into the DDSA.
When the driver door module (DDM) receives a driver door window switch request from the DDSA, the DDM examines the request and inspects to see if it has received any messages from any of the other vehicle modules prohibiting the movement. If no prohibitive messages have been received, the DDM then applies power and ground to the driver door window motor to move the window as requested.
When a passenger door module, passenger front door module (PDM), LH rear door module (LRDM), or RH rear door module (RRDM), receives a window switch request from, either the DDSA or the window switch mounted locally to its door, the passenger door module examines the request and inspects to see if it has received any messages from any of the other vehicle modules prohibiting the movement. If no prohibitive messages have been received, the passenger door module then applies power and ground to its associated window motor to move the window as requested.
So do yourself a favor an take it to a qualified repair shop.
Nov 22, 2017 | Cars & Trucks
Where is the fuse for the right rear electric window on a 2002 Taho
There is not a separate fuse for the right rear window if the fuse is blown the entire power window system would be inoperable, You most likely just have a defective window lift motor inside the door.
Apr 30, 2017 | Cars & Trucks
Can't find the window fuse for 2003 caddy cts
Check inside trunk under carpet on rear seat back support.
Nov 12, 2016 | Cars & Trucks
How to fix my rear tailgate window
check the fuse/relay. if it is neither of these check the switch with a multimeter. If you can hear the motor trying to move the glass when you try the switch it may be the regulator needs attention. It may be the motor needs to be replaced.
check fuse and relay along with the switch first then the regulator and motor afterwards. Replacing the small electronics is obviously easier than having to open up the tailgate to check the mechanics of the winedow.
Sep 13, 2015 | 2004 GMC Envoy XUV
The power windows wont work it makes a clicking sound
The clicking is the motor relay most likely. You don't say if its one window or all windows. Can you give more info as to what you have checked? Fuses etc?
Oct 20, 2014 | Gentex 2003 Hyundai Sonata - All Sonata...
Where would i find fuse for rear pasenger door window
Glovebox F15 30amps rear electric windows
The fuse is for both rear windows so if one is working then it's not the fuse
possibly the rear windows regulator motor has failed.
Apr 01, 2013 | Citroen C5 Cars & Trucks
My rear windows (just rear) are inop on 92 chrysler lebaron conv
Check your fuse block first. If all is well, replace window motors.
Feb 28, 2012 | Chrysler LeBaron Cars & Trucks
2003 ford escape. radio and sideview mirrors don't work, but clock in radio does. I checked both panel of fuses.
for radio
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna or antenna cable
  • audio speakers mounting/speaker cones
  • Radio ignition interference capacitor, radio frequency interference suppression bond
  • Central junction box (CJB) fuses:
    • 19 (10A)
    • 12 (5A)
  • Battery junction box (BJB) fuses:
    • 19 (40A)
    • 20 (40A)
    • 27 (10A)
  • Connectors
  • Ignition switch
  • Circuitry
  • Audio unit
for mirrors
  • Exterior rear view mirror(s)
  • Interior rear view mirror
  • Central junction box (CJB) Fuse(s):
    • 8 (10A)
    • 16 (10A)
  • Circuitry
  • Exterior rear view mirror motor(s)
  • Exterior mirror control switch
  • Heated rear window switch
Jun 28, 2009 | 2004 Ford Escape
Sideview mirrors dont move certain ways.
I researched the maintenance manual. The fuse you need to replace is fuse 20 in the under dash fuse box. It controls side windows, washer motor, rear view dim function, and possible seat memory. There are a couple that link to the mirrors, but this is the one for this problem.
Jan 24, 2009 | 2004 Acura TL
Driver window would not go up. All other windows work.
Have to remove door panel and check motor by by passing switch, many of the motors have a thermal switch on them and over time they tend to get a bad connection. I have been able to in many case hit the door panel hard right over the regulator and they would start working, I doubt it is a fuse so if the motor checks good it pretty much would have to be the switch, at least that is how I would do it..Merry Christmas and Happy new year
Dec 24, 2008 | 2002 Ford F250 Super Duty SuperCab
1999 to 2012 Ford F350 Truck Super Duty Power Window Regulator with Logo
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
terry stevens
Speedracer70
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
