Question about Xerox DocuColor 12 Color Copier
Xerox docucolor 12 won't print yellow toner - Xerox DocuColor 12 Color Copier
  • 56 Answers
SOURCE: Xerox Docucolor 12 color copier language problem
Hi, there is no way to change language on Touch screen without calling Service. Best regards.
Posted on Dec 27, 2007
  • 2072 Answers
SOURCE: docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Posted on Mar 12, 2008
kevin000
  • 1847 Answers
SOURCE: Docucolor 12 error 9-356
That is a yellow toner empty message
Posted on Jun 09, 2008
  • 62 Answers
SOURCE: Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
print cartridge is past its best. If you get a new one and the same thing happens, its the developers that need changing
Posted on Nov 19, 2008
  • 8 Answers
The 2045 has a toner and Dev collection as dev ages ist looses its ability to charge and discharge and is then deposited into what is called the toner waste container. It has a different name but serves the same purpouse. TO answer the Question on the no power somemore info is needed. When you turn on the DC12 can you hear the fans run? do your hear any other noises when you turn your unit on??
Posted on Jan 02, 2009
My xerox print yellow light
1) your toner does not sypply properly
check
remove ur yollow toner (when machine is on)
go to component control input code
009-012 press start
does ur yellow motor run
check
009-032 dispence motor run
some wheel running below ur yellow cartirdge
if yes solve that problem
other wise be sure ur using original toner
Aug 24, 2010 | Xerox DocuColor 12 Printer
XEROX Docucolor 12 Color Developer PN needed HELP
DEVELOPERS:black 5R616 ; yellow 5R 619 ;magenta 5R 618;cyan 5R617
TONER : magenta 6R1051 ; cyan 6R1050 ;yellow 6R1052
Sep 14, 2009 | Xerox DocuColor 12 Color Copier
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Jun 09, 2008 | Xerox DocuColor 12 Printer
DC12 - Yellow Banding (top to bottom)
There is a software patch on the Xerox.com site.
Once there click Support and Drivers.
Once there in the search box enter dc 12
Once to the Support area. Type in Yellow in the search box. That should direct you to the patches.
I hope this helps.
Dec 30, 2007 | Xerox DocuColor 12 Printer
XEROX DOCUCOLOR PRIN 12
Check the blade (knife) , maybe dont clean all residues, sorry form my english, check the fuser roll, this roll have a teflon, mabybe need change!
Dec 26, 2007 | Xerox DocuColor 12 Printer
DC12 prints with no yellow toner
Sounds to me like the yellow developer housing has failed.
Either replace the housing or call for service for them to do that.
Dec 14, 2007 | Xerox DocuColor 12 Color Copier
Gradient Problem on a DOCUCOLOR 12
Hy i had a similar problem some time ago.
You need to go to then xerox enginer tools menu
Then go to the MAX SETUP
Then toner concentration adjust
And then you have to rise up the toner concentration on low and medium print.
a couple of tries and maybe your problem will be fix.
Nov 27, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
27 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
