Question about Xerox DocuColor 12 Printer
Docucolor 12 how do you put setting back to factory resets
4 Suggested Answers
  • 62 Answers
SOURCE: Docucolor 12 Power problem
Check the fuse in the plug, 13 amp, the trip switch on the back of the machine, if not then its probably a power supply problem on the machine. you dont actually state the docucolour which has this problem.
Also as for the waste containers, why do you want to know about something that is a given. The answer is they work differently, if you really want to know about the inside workings i will tell you but you will be bored
Posted on Dec 28, 2008
  • 8 Answers
The 2045 has a toner and Dev collection as dev ages ist looses its ability to charge and discharge and is then deposited into what is called the toner waste container. It has a different name but serves the same purpouse. TO answer the Question on the no power somemore info is needed. When you turn on the DC12 can you hear the fans run? do your hear any other noises when you turn your unit on??
Posted on Jan 02, 2009
faxman789
  • 297 Answers
SOURCE: i need driver for docucolor 12 for vista
This product is not supported in the Microsoft Windows Vista Operating System.
but here is a link for Vista. Choose either Vista x64 or Vista and see if it becomes available:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=DC12LP&Xlang=en_us&Xcntry=USA&prodName=DocuColor%2012%20Printer
Posted on Jan 17, 2009
The application is locked
Are you locked out of your router? If so put a pin in the reset switch and unplug the router for 12 seconds while keeping the reset button pushed in. After 12 seconds plug it back in and when lights start to turn on release the reset button. It should be back to factory settings.
Apr 15, 2011 | Computers & Internet
Out of fuser web.I need to reset it on nwm.How I can do it ? Please help Mashine is xerox 5790
1.start +0
2.6789
3.dc135 hsfi line 20 clear
4.nwm accsess
6.read write
7.reset 3984 to 0,
8.reset 3985 to 0,
9.reset 3986 to 0,
10.reset 3987 to 0
Then open mashine door,take out fuser web sensor and put it back.
Message out of fuser is gone.Now it is ready to make copies.
Apr 12, 2010 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 not recognizing network controller
check ur fiery card that connect to copier
remove card clean any dust at the pins / slot lines then try
Sep 12, 2009 | Xerox DocuColor 12 Color Copier
Offset catch tray failure docucolor 2045
there must be a fault with the tray or wiring. There is nothing else that can cause this fault
Feb 14, 2009 | Xerox DocuColor 12 Color Copier
Dec 28, 2008 | Xerox DocuColor 12 Color Copier
NVM settings
In tray one there is a hidden compartment take a flat blade screwdriver to the cover as you are looking directly down at the top of the front of the drawer you should be able to open the top of the compartment. In there is what is called the birtcertificate for the machine and the original NVM settings are in there.
Dec 24, 2008 | Xerox DocuColor 12 Printer
NVM settings for Splash RIP
i found all the correct settings here : http://thedigitalhut.net/device-not-responding-on-the-splash-g-640-and-xerox-docucolor-12/
Aug 28, 2008 | Xerox DocuColor 12 Printer
Xerox docucolor 12 please power off and turn back on.
you have a heater problem. The machine times out if it doesn't see an increase in temperature within a set time. What code are you getting?
Aug 25, 2008 | Xerox DocuColor 12 Printer
How do I reset the indictor on a Dell printer cartridge after refilling it? xerox docucolor 12 printer
If this is a monochrome laser toner cartride you may need to purchase a CRUM chip to replace the one on the toner cartridge. If you had your cartridge refurbished by a company who specializes in this and they did not reset the CRUM you do not need to use them in the future. There may be a way to cancel the add toner message in the service mode so I will keep checking and post an updated solution should I find any available information. Could you confirm that it is a Xerox Docucolor 12 printer made for Dell?
Jun 03, 2008 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
