Question about Water Dispensing & Filtration
Aquila water filters
Can't undo body of unit to change filter on unit
SOURCE: I can't undo the filter cap
i had same problem so removed the inlet pipe on the pump at the back of the filter and removed debri from back of filter [screws coins and a darning needle] because of this the design of the lid would not allow it to open.........
Posted on Apr 12, 2009
  • 44 Answers
SOURCE: changed water filter red light stays on
you will wither have to push the light switch button 5 times or push and hold reset button or 2 at a time. Look at the display carefully it usually will tell you what you need to do
Posted on May 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: "change water filter" continues to flash when dispensing water
I believe your new Jen-Air has an old model number placed above your post. If you had a newer model nuber I could see if changes were made to the solution. The ods are no changes. I it possible you may have missed removal of te flilter plug? It also is your first time and to press the 2 buttons at same time for 8 to 10 seconds may be a little confusing. I bet after this time you will have this down to an art! here is what I could find without the vorrect model number if that is what happened or not.Jenn-Air
Press and hold the light and lock buttons until the change filter light flashes.
It is very easy to reset your filter indicator light on your Maytag refrigerator. Simply press and hold the light and lock buttons, on the dispenser, for about three (3) seconds, until the change filter light blinks.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the filter light flashes (usually 5-10 seconds).
Posted on Mar 05, 2010
BMT60
  • 126 Answers
SOURCE: new unit never used found the water filter cracked
THE FILTER HOUSING MAY HAVE FROZE AND BROKE. MAY HAVE FROZE ON TIME IN SHIPPING. CALL ELECTROLUX THEY WILL SEND YOU THE PART AND A TECHNICIAN TO FIX IT. SO IT COULD BE REPAIRED IN ONE TRIP.
Posted on Apr 24, 2010
Testimonial: "good answer, water filter replaced. water is still collecting at the bottom of the ice box, the new water fiter is not leaking, ???"
SOURCE: water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Posted on Jul 09, 2010
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
How do I change the fuel filter?
you need a 5/8" wrench and a 7/8" wrench to undo the fuel lines from the filter, then a 10mm socket with extension and ratchet to undo the bolt that holds the filter bracket to the frame then you can change the filter. there is usually a flow arrow marked on the filter make sure its installed(filter) correctly.
Sep 21, 2014 | 1997 Buick LeSabre
Hi, I have a thermoplastic sand filter t450 model. Every time I leave it in filter mode, water from the pool seems to drain out rather than filter water from pool. When I leave it in backwash mode,...
The "spider"gasket in the backwash valve needs to be replaced. It is not hard to do. If you undo the 6 bolts on top of the valve lid the "key assembly" will lift straight out. Inside the valve body you will see the gasket.
Aug 06, 2013 | Pool & Spa
I need to check the filter on a beko wm6143s. Where is it?
If you cannot remove the filter cap, do not pull or twist with pliers, this will only break it.
Instead, turn of power and water, pull the entire washing machine out and then tip it backwards at approximately 45 degrees or to the point where it is balanced.
Then undo the only visible screw behind the filter cover, slide entire lower cover to the right. this will reveal three screws, undo these and rotate the filter cap and pump body anticlockwise until the lugs line up with the gaps in the front panel. disconnect the wiring plug from the top then lower the pump below the chassis of the machine.
Remove the black hose on the left hand side by gripping the hose clamp with pliers and pushing off. The offending items (two hair grips and a shirt collar bone in my case) will be visible in the body of the pump, fully withdraw the filter cap to check for other debris.
Reassembly is the reverse of disassembly.
Jan 12, 2012 | Beko Washing Machines
Where is the throttle body on 2007 jeep patriot 2.4
In the 2007 jeep patriot the throttle body is located on the bottom right hand corner of the engine near the cooling fan, under the coolant hose coming from the radiator. If you follow the air intake hose from the air filter, which sits right above the battery, it ends at the throttle body. Once you take the battery out, undo the air intake hose from the filter, remove the filter casing, and undo the coolant hose from the engine you will have much easier access to the throttle body. The hardest part is loosening the clamp on the air intake hose connecting it to the throttle body (tight space). Once that hose is off, the throttle body has 4 bolts to the block and 1 mounting bracket bolt and than it comes out easy.
Jan 07, 2012 | 2007 Jeep Liberty Sport
Engine diagram 1997 buick skylark/thermostat
follow the water inlet pipe to water pump the thermostat housing connects to water pump this is for 2.4l engine you have to remove exhaust manifold heat shield.you will see the water inlet pipe going to water pump inlet thermostat housing.for the 3.1 engine follow top radiator hose to thermostat housing you have to remove air filter air duct and filter housing , you have to remove throttle body unit with coolant hoses, you have to disconnect accelerator cable, transmission down shift cables at the bracket bolts to throttle body.once you remove throttle body unit then you can see and remove the thermostat housing to replace thermostat.you need to buy new throttle body gasket,and new small coolant hoses connects to the throttle body unit.have extra gallon antifreeze dexcool on hand.
Nov 15, 2011 | Cars & Trucks
GE SmartWater MWF Refrigerator Filter is making noise when dispensing water
The filter body for the unit is poorly designed and can only stand maybe 8 filter changes before it starts failing to open fully with the new cartridge. As far as I can tell the only solution is to replace the filter body.
Oct 14, 2010 | GE GSH25JFT
Can you tell me if the top inlet is the in water from the other filter i have and the lower inlet is the out water or have i set it up wrong
Water should normally go into the top of a filter and out the bottom.
Your pump should be sucking water from the body of water, through the pump, into the top of filter #1, out the bottom, into the top of filter #2 out the bottom back to the body of water.
Alternatively, the water may be coming from the body of water into the pump, into the top of both filters at the same time, out the bottom of both filters and back to the body of water.
Water SHOULD NOT go into the bottom of the filter when running in filter mode. If this is the way you have it, all the junk you filter from the pool will be stuck in the laterals and the sand in the bottom. You will never be able to clean (back wash) the filter.
If your filters are DE or Cartridge, the same idea applies.
I hope this has answered your question.
Thanks for your interest in FixYa.com
May 26, 2010 | Garden
How to change an air filter in a 1993 nissan 300zx
on a 300zx lift the bonnet/hood.. inbetween the headlights (the panel with the zed emblem in the centre) underneath it is the standard airbox..to remove the panel there are 2 bolts holding it to the chassis.. undo these and the nose panel lifts out.. yo can know access the stock air box.. undo the clips on it and lift the top off to access the panel filters.. inspect/replace and do steps in reverse to put it all back together
Mar 10, 2010 | 1993 Nissan 300ZX
Oil change
hi mate its very easy to do a oil change basically 1st warm the engine up to make the oil thin so it all drains then you need to take the bottow body off then underneith the engine you will see a plug undo it and drain the old oil into a bowl and then i will reccomend changing the oil filter at the same time as the filter will be dirty and new oil mixed with dirty oil not a good thing then once the oil is empty unscrew the oil filter then on the oil filter put a bit of oil on the rubber seal then screw the new oil filter on and do the plug up tight then unscrew cap on side casing and pour oil in that hole then once the oil reached 1/2-3/4 on the sight glass located on the side casing at the bottom put the filler plug back in and put body back on good luck bud
Aug 24, 2009 | 2001 Yamaha YZF-R6
Water Dispensing & Filtration Logo
107 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
