Question about Ovens
Simpson 2001 oven wont work light keeps flashing
4 Suggested Answers
vijaivee
  • 120 Answers
SOURCE: Oven door not fully closing
some problem in the lock change the lock
Posted on Jun 12, 2011
SOURCE: Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Posted on Jun 13, 2011
  • 3 Answers
SOURCE: simpson wall oven 2001 wont turn off unless its turned to automatic.
Oven thermostat is faulty. needs replacing.
Posted on Feb 17, 2012
My oven doesn't work its a simpson apollo and it got 6 buttons under the clock
Hi,just food for thought,is the lights flashing if so you might just have to set the time,if there are no lights flashing has the cooker got a plug check the fuse has not blown.
Jun 08, 2016 | Ovens
Simpson Neptune, atlas series electric oven isn't working.
Hi If you have Simpson Neptune 3U 602 then it may be to do with the timer function. This also happened with my oven.
There is a red section on the face of the clock. The oven seems to work if it shows the hand icon. I'm not sure what it symbolises yet, as it's a new oven for me, but it is now working. You can change the icons by turning the left nob left and right. Hope this helps.
Jul 07, 2012 | Ovens
What are the dimensions of a Simpson 2001 wall oven
4 burners. 540mm wide x 600mm. Oven is 1040mm high at rear and 890mm at front. Good condition. Only selling because I am upgrading.
Just to confirm is youre stove a Simpson Riviera ?
I hope this helps
Feb 20, 2012 | Ovens
Simpson wall oven 2001 wont turn off unless its turned to automatic.
Feb 17, 2012 | Ovens
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
Have shifted house, my Simpson Apollo ceramic oven won't work. The elements are fine. The timer and auto lights are flashing. I can't seem to make it stop. I have no user guide to help fix this error,...
The timer needs to be set to manual mode for the oven to work. Turn the oven control on. Play with the buttons on the timer. Try all combinations. It may take 5 or more minutes. When the oven indicator light comes on you will know it is on manual and the oven is working.
Feb 26, 2011 | Ovens
Simpson 2001 series upright electric stove oven does not get hot only gets warm
It could be the oven element (behind the cover plate in the back of the oven), or the fan not blowing the heat into the oven.
Aug 19, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
