My Acer Aspire AX1700-U3700A turns on but no signal out to the monitor
    Master:
  • 568 Answers
Are you able to hear the beep sound?
Posted on Feb 02, 2016
2 Suggested Answers
PaulRepair
  • 66 Answers
SOURCE: need user manual for aspire AX1700-U3700A PDC
The link to those Acer manuals is on thier website for download:
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3425#results
Paul
Posted on Mar 06, 2009
Acer aspire ax1700-u3700a. The dvi port has stopped sending signals to the monitor but the vga port works. I use the vga port but the computer sometimes gives blue screens then strats back woring normally....
I can see you do have two issues here.Let us first fix the DVi port.Please see follow the steps below.
1. Please check video configuration by looking it up on the PC control panel.
2. Please make sure you choose the both DVi and VGA port by simply placing "tick" on the box.
On your second issue.Please follow the steps below
1. The "blue screen" normally comes up if you a faulty VGA cable or the connection is somehow loose.Please check if it is properly plug-in.
2. If the problem continues,I would suggest please contact the manufacturer or the store where the
item was purchase
Sep 04, 2011 | Acer Aspire AX1700-U3793A PC Desktop
I have an Acer AX1700-U3700A and I was working online and stepped away came back and the computer was turned off. I Pressed the power button but nothing turn on .... I have not idea what happened .... Is...
  1. Check your computer is getting power, (reconnect power from outlet)
  2. if power is ok, then open your computer cabinet, disconnect motherboard power (24 pin), then make short Green and Black wires and check power supply fan is working or not, (Switch off computer when disconnecting)
  3. if fan is not working replace power supply (SMPS) and check (working fan means SMPS is ok, but in some occasions Fan may work in defective SMPS )
  4. if the power section is ok you need check you mother board
Thank you...
Please rate me if it is valuable
Aug 28, 2011 | Acer Aspire AX1700-U3793A PC Desktop
My acer ax1700 u3700a will not turn on. I think it is the power supply, but I'm not sure
When I had this problem it turned out to be my video card (unless my p/s is on its way out and just won't power the video card anymore). Removed the video card and switched to onboard VGA and it boots fine. Had no Win7 Aero though so I went into bios and set it to onboard VGA and UMA 256 instead of Auto and my Aero is back as well.
Aug 26, 2010 | Acer AX1700-U3700A PC Desktop
I have an acer AX1700 which boots up but does not give any signal to the monitor.all lights are on from the computer as well as the monitor but the monitor stays black. cables are plugged in...
Before you buy a new graphics card, please try the monitor on another computer. If it's works on another computer, you need to troubleshoot the your machine.
Bring another monitor to your computer and connect it, if it works, then there's no problem with your graphics card. Must be startup or interfaces problem.
(Note: do all the connections before you power on the computer and leave your monitor On before your switch on the computer.)
If another computer works on your computer, then replace with a new display cable (vga/hdmi/dvi which suits your monitor).
Do let me know after you are done all these.
Good luck.
Thanks for using FixYa.
Jun 30, 2010 | Acer Aspire AX1700-U3793A PC Desktop
Keep getting the cannot read disc message
Please confirm if your CD Drive unable to read any perticular format of files....
Also, you are CD Drive or DVD Drive... please provide the model number aso.
Jun 28, 2010 | Acer AX1700-U3700A PC Desktop
When you turn it on, does it respond? Do any lights lit up? Do you have a known good ac adapter to try it with? Or is the ac adapter you are using lits up and/or powering on a different computer?Try to test both to check the functionality of the ac adapter and the port. If ac adapter will work with a different pc, then possibly the port is damaged. You may need to replace the motherboard. If still it wont turn on, then you may just need to replace the ac adapter.
May 27, 2010 | Acer AX1700-U3700A PC Desktop
Acer AX1700-U3700A with variable Audio on HDMI
Your problem isnt in your PC, it's because you chose the onboard sound to listen to music etc, which is normal. Unfortunately, you need to choose the HDMI Audio output if you want sound on your TV FROM the HDMI cable. Right click the sound icon located to the lower right side of your screen and choose (adjust audio properties). Now go to the audio tab and click the output device window and choose your HDMI audio output, whatever it may be called. Just pick the one that wasn't selected when you opened it and click ok or apply. Now all audio output is controlled by your Video card lol. Crazy aint it?
Feb 14, 2010 | Acer Aspire AX1700-U3793A PC Desktop
Cannot bring up full bios with F-12 acer ax1700-u3700a What do I do?
BIOS is brought up by hitting F2 or in some cases the delete key. F12 is normally for bringing up the boot menu, whether you want to boot from the dvd or the hard drive. Try F2 or the delete key
Sep 16, 2009 | Acer Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
