Question about Powermatic 1791213 15HH 15" Planer with Byrd SHELIX Helical Cutterhead
Turned my blades now have dips and lines what to do
Oil dip stick
Check online: Enter your car make, model, year and engine type and search for "oil dipstick length/specifications."
Oct 02, 2015 | 1990 Dodge Dakota
Lost dip stick (oil)
What motor? it varies. I did see that JC whiteny sells properly cut length ones for all the motors and they are pretty cheap
Why does the transmission dip stick keep coming out on my 2006 Jeep Liberty Diesel 4x4
it pops back>? that it? (coming out?) leaking fluid? that?
inserted wrong, ?
some need to be inserted correctly or they jam up inside.
true for many sticks, no round.
flat blade sticks,
or damaged dip tube.
Feb 21, 2015 | 2006 Jeep Liberty
Uneven cutting
Could be bent Spindles. Easiest way is to mark on deck where point of blade is and rotate blade around if both ends don't match mark on deck highly likely bent blade or spindle. Id say bent blade more likely.
In my experience Gator blades in general work fantastic.
Apr 28, 2013 | Briggs & Stratton Garden
Blades for a 2009 craftsman lawn tractor will not work
the oil coming from the muffler smell the oil on the dip stick to see if it smells like gas if so the needle valve in the carb is leaking the blades not turning on has oil dripped onto the clutch and burned it out?is there a bad safety switch not allowing the clutch to turn on ?
Apr 30, 2012 | Garden
The trimmer on my Braun 1775 FreeControl shaver has stopped working. When it is engaged, the pitch (sound) of the shaver changes in the usual way with the usual increase in vibration. However the trimmer...
The trimmer is either broken or clogged up with a combination of shavings and skin oil. If it is broken, there are no replacements available. If it is clogged, you can fix it by thoroughly cleaning it. Dip the blades of the trimmer into some rubbing alcohol or other mild solvent type liquid. Soak it for about one minute. Then take an old toothbrush and firmly scrub the teeth. Then turn it on and it should free it up. If it still doesn't move you can advance the blade manually to get it 'unstuck'. One of the blades is fix and the other moves back and forth. You should be able to see which one is supposed to move by sight. Take a small flat screwdriver or similar object and push the blade to each side once. Turn it on and it should move freely. Dip the trimmer blades back in the rubbing alcohol while it is running and let it run for about 15 seconds.
If still not working it is beyond repair. The easiest and least expensive way to get working again would be to purchase a new ;lower unit' which includes the trimmer. You will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-1775-freecontrol-lower-unit-p-828.html
Aug 24, 2011 | Braun FreeControl 1775 Hair Trimmer
I'am trying to set the timing for a 96 mit.eclipse
you have to line up all 3 of your tjmjng marks.Is your engine single head or double overhead cams The marks have to line up.Firstyou have to remove the belt.Then remove harmonic balancer to get to the timing gear sprocket.It has a blade attached to it with 3 fins in between the fins is a little dip that is the crankshaft position.align that dip with the mark below the crankshaft position sensor.then you have to do the same with your camshafts.Then replace the belt and spin the the crankshaft clockwise to the aligment mark they should all stop on their marks.
Apr 18, 2010 | 1996 Mitsubishi Eclipse
How do I change the oil on my craftsman lawn mower
put a small tub on the ground , remove the dip stick , and tilt the mower on its side with the air cleaner / carb , up and let it drain out . or there is a drain plug under the motor near the blade
Apr 12, 2010 | Craftsman 25cc Gas Line Trimmer
Trimmer not working
the trimmer may be jammed with hair particles. clean the trimmer blades really good with an old toothbrush dipped in rubbing alcohol. you can also turn it on with the tip of the trimmer blade dipped in a shallow container of alcohol.
if your trimmer blade is sufficiently clean and still doesnt work, the rocker arm that moves the blade must be broken. Remington does not offer replacements for the trimmer part
Jan 16, 2010 | Remington Microflex R-842 Electric Shaver
Won't start
the blades may be locked. remove the spark plug cap so the mower won't start unexpectedly. tilt the mower on its side, air filter facing upwards. work the blades until they loosen and turn freely.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Powermatic 1791213 15HH 15" Planer with Byrd SHELIX Helical Cutterhead Logo
67 people viewed this question
Top Powermatic Masonry Tools Experts
Tom Chichester
ray gallant
Are you a Powermatic Masonry Tool Expert? Answer questions, earn points and help others
