Question about VistaQuest 8" Digital Photo Frame
How do I delete photos from the photo frame to add more?
I deleted some photos from the thumb drive but they still show up on the digital frame?
you don't say which exact photo frame but here are some ideas that work on many. try powering off and unplugging, wait a minute or so, then plug back in and turn on. are they gone? if not, look for a reset button, pin hole and try resetting. good luck.
Mar 10, 2015 | Photography
Can't delete photo from frame's internal memory
Select play photo files on the camera. then hit the trash can logo, delete them from there.
Jun 22, 2017 | Cameras
How do i delete photos from my digital frame
you click the choice button .and it will indicate the two choice . save or delete .you choose the delete .and click the ok button .
wall light
Apr 28, 2012 | Omnitech 36972 Digital Frame
How to add photos in jassop 7'' photoframe
well first install the software into your pc run the cd and install the Image Shuttle.exe file. then plug USB cable end"B" to fram and "A" to pc windows should auto detect and install the required drivers
to import files connect the frame to your pc using the USSB cable open IMAGESHUTLE program check if it detects your frame using folder browser find the pics you want to add highlight the pic and click ADD once done choosing your pics click the TRNASFER button
hope that helps....
Jul 12, 2011 | PANDIGITAL 7" Digital Photo Frame With...
Removing certain picutes from the frame
Hi, if this is a Pandigital frame, go to the manual pg.9 and follow instx under"Delete Photos from Internal Memory.
If it is another brand,try: on the Home screen menu,select Manage Photos( Make sure you do not have a Flash memory,camera card,usb etc connected to the frame!) and, under the Delete select the individual
photos to be deleted.
Hope this helps, but,I'm only familiar with the Pandigital
Dec 21, 2009 | Polaroid IDF-1030 (826219006783) Digital...
How to delete a picture from a digital photo frame
Using the USB cable you can connect to your computer and change the photos or delete the ones you no longer want.
Plug the USB into your computer - If you don't see the pop up message letting you do this, Go to my computer and check the photo frame appears as a new device.
May 11, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Deleting Individual Photos
Hey,
Hit the exit button on top of the frame several times until you get to a screen that has options like, photos, music, files, etc. arrow to the photo option and Enter. Next move the arrow to highlight the photo you want to delete. Then hit the Setup button and you will have the delete photo option.
Hope this helps
Mar 02, 2009 | PANDIGITAL 7" Digital Photo Frame With...
I just purchased a digital photo frame, the DP-758. I loaded photos from my USB key, 52 photos. I somehow have 233 photos on the photo frame, I don't know how. I would like to know how to delete...
hi there
your photo frame has not got a built in memory so it can only read pictures from the card you put in and only while the card is inserted. these extra pictures are either on your card, which you can delete yourself via your p.c., or they are stock demo pictures on the picture frame which can't be deleted.if you insert your card before you switch the frame on it should read only the card.
hope this helps
beergut707
Oct 08, 2008 | Coby Televison & Video
VistaQuest 8" Digital Photo Frame Logo
43 people viewed this question
Top VistaQuest Photography Experts
Tony
Are you a VistaQuest Photography Expert? Answer questions, earn points and help others
