Question about Sharp AR-C240P Printer
Sharp AR-C240P Printer Prints Everything with red cast
My Sharp AR-C240P printer got 4 new drums and 4 new toner cartridges within the last month. Since the changes, it now prints everthing color in heavy burgundy and reads that the yellow toner cartridge is low. My Sharp dealer has worked on it and found nothing wrong, just manually adjusted the color saturation down and replaced the yellow toner and sensor. Nothing has changed. Can you offer any help?
IF YOU HAVE NOT CHANGE THE DRUM TRY IT. FOR ANY COLOR THAT IS RUNNING OVER POWERING.
Posted on Jan 14, 2010
My Sharp Ar-M155 is displaying d message replace the toner cartridge. I ve tested d cartridge with another machine and it is working perfectly
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jul 07, 2011 | Sharp Office Equipment & Supplies
F4-02 Improper Cartridge message on Sharp AR-M450N multi-function Tried everything -- unplugging everything -- turning everything back on then tried #*C* 14 enter 1 enter also tried 15 enter 1...
You may just have a Bad Toner Cartridge... It will happen from time to time..... There is a IC chip on the back of the cartridge, it may be bad or the toner feed screw is bound up... Replace the cartride with a new one..... Also, is it a OEM toner cartridge or a genaric one?
May 04, 2010 | Sharp AR-M450N Copier
My ar-c240p sharp printer prints very nice sharp prints both color and black sometimes. Most of the time it prints light gray and washed out colors. This may happen from on print to another within...
Hello.. Generally when this happens the developer rollers are worn out and need to be replaced. This is a job best left to a trained tech. Thanks for choosing fixya! Regards, Joe
Nov 13, 2009 | Sharp AR-C240P Printer
Sharp AR-C240p change yellow toner counter still say's 0
please dear your yellow toner is not original, so you change it or buy original thanks
Jul 30, 2009 | Sharp AR-C240P Printer
All new toner but prints everything blue
I kinda don't doubt it at all. It could be a bad lot of toner, or another problem with a mechanism within it...regardless, you're cartridge is defective -return it.
Jun 15, 2009 | Brother HL 1440 Laser Printer
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
Sharp ar-161
may be the new toner or the drum was not good. try it with a old cartridge.
May 29, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-C240P Printer Logo
151 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
