2010 grand marquis a/c controller troubleshootging
5 Suggested Answers
olds97_lss
SOURCE: Mercury grand marquis 1997 temperature control
I'm not sure if yours is identical to mine since yours is second gen and mine is third gen, but with mine (1998 MGM), the heat was stuck on all the time. Full heat would practically cook your feet and you couldn't shut it off.
It was a servo/servo arm that controls the hot/cold mix door. The part was $15. The labor was $700. They had to take the entire dash out of the car to get at the part. Required two more visits due to a missed electrical connection to a daylight sensor and a vacuum issue that made the car stall when put into reverse.
My car had 150K on it at the time. Has 165K on it now. Still runs great and looks great. It's now my wife's auto and I drive a 2006 MGM.
Posted on May 13, 2009
  • 83 Answers
SOURCE: 2000 grand marquis cruise control not working
Have seen this problem before. You need to look under dash at brake pedal and find a blue switch with plunger contacting pedal, disconnect connector and jump with a peice of wire and drive to see if cruise works and if it does replace deactivation switch this should get you going.
Posted on Aug 26, 2009
dttech
  • 4803 Answers
SOURCE: heater and airconditioner control on mercery grand marquis
If the fan will not run on ANY speed in your Grand Marquis, the problem is most likely NOT the control switch.
Check for power and ground at the blower motor connector. If power and ground is present, replace the blower motor. Otherwise, the problem is most likely a failed blower speed control module (VERY common). The blower motor speed controller is located in the A/C evaporator housing just below the heater hoses.
Note: It is also common for a bad blower motor to CAUSE the controller to go bad. You MAY have to replace BOTH.
Posted on May 17, 2012
  • 4 Answers
SOURCE: lcm 2004 grand marquis
the lcm is just right of the steering wheel column and left of and below the radio. you have to remove a plastic cowling under the steering column that is attached by two plastic push pins on either side of the column. the cowling slides out and the lcm is exposed. it's a black box a bit bigger than the size of a brick and has three wire harnesses plugged into it. the lcm is held in a metal cage bracket with two hex head screws. After removing the screws, the lcm can be pushed up slightly and out of the cage toward the front of the fire wall. it's easier to detach the harnesses after the lcm is out of the cage.
Posted on Sep 04, 2012
1995 mercury grand marquis clock don't work but everything else does. How to fix it?
In dash clock display not working ' 4.6L Based Powertrains ...
www.crownvic.net > ... > 4.6L Based Powertrains
Feb 21, 2006 - 2 posts
On my 95 MGM with almost 145k miles, the in dash clock stopped displaying when ...1995 Mercury Grand Marquis 204k - Sold 08/11 - Gone but not forgotten! ... SteveS: Idon't see poll manager in replies, except north central. Airbag Light and No horn = clockspring? ' Body and ...
Feb 27, 2014
Horn No Longer Works ' Body and Interior
Nov 12, 2010
Cruise control stopped working! ' 4.6L Based ...
Apr 20, 2008
setting clock in 89 crown vic ' Box Tech
Nov 13, 2006
More results from www.crownvic.net
Dec 25, 2015 | Mercury Cars & Trucks
How to find out what causes the oil to rise
I'm not sure about the question but if you mean oil pressure,it can be the pump going bad,head gasket leak,dead cylinder. Check one thing at a time until you find the issue.
Apr 16, 2014 | 2010 Mercury Grand Marquis - All Grand...
Climate control unit
check fuses then find out if the actual climate control is not working replace if not. test for power and resistance.
Mar 04, 2013 | 2006 Mercury Grand Marquis
Where is cabin filter located in mercury grand marquis 2010
My guess is under the hood on the firewall. There is a plastic cover which you pry open to expose the filter compartment.
Sep 03, 2012 | 2010 Mercury Grand Marquis
Why cant you tow more than 1500 lb with 2010 grand marquis
Because the car and transmission are not designed for heavier loads than this.
Jun 06, 2012 | 2010 Mercury Grand Marquis
Heater and airconditioner control on mercery grand marquis
May 17, 2012 | 2001 Mercury Grand Marquis
I own a 2010 grand marquis and I cant put gas in it unless I pump it realy slow. Is this a common problem?
yes, while fueling just barely stick the pump nozzle in the gas neck, you probably wont be able to pump at full speed but you should be able to pump a little faster
Jan 14, 2011 | 2010 Mercury Grand Marquis
Replaced Oil Filter Adapter Gasket 1995 Mercury Grand Marquis to fix slight Oil Leak. Got red oil warning light. Replaced Oil Pressure sending unit but still have red light. Suggestions?
We performed exactly the same repair on December 28, 2010 withexactly the same outcome. Finding no other references to this oil pressureproblem anywhere on the internet and the fact that they both happened the samemonth, I can only wonder if there are some incorrectly made gaskets hitting theshelves.
Dec 04, 2010 | 1995 Mercury Grand Marquis
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
