Question about Echo Garden
How do i remove the flywheel from my echo 303 chainsaw?
4 Suggested Answers
  • 211 Answers
SOURCE: i need to remove the flywheel on a 288 husqvarna chainsaw
you need a rope with nods on it ,put it on the sparkplug gauge to block the piston in the cilinder,after that try to unlock the clutsch and the flyweel.Then disassembly the engine and change the seals.
best wishes Mihai71
Posted on Nov 28, 2008
  • 582 Answers
SOURCE: Where do I find the proper tools to remove the
MOST OF THE TIME I USE A AIR GUN AND A AIR WRENCH .IT DEKIVERS THE FORCE WITH OUT BREAKING ANYTHING. A 3/8 INCH BUTTERFLY GUN WORKS WELL FORN THESE SMALL TASKS
Posted on Aug 26, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a echo cs5000
It is close 0.125 (one hundred and twenty five thousandths.) I have used an open match book as a gap guide on flywheels for 40 years... all make all brands and it works like a champ!
0.12 to 0.16 is acceptable.
Thanks for choosing FixYa,
Kelly
Posted on Aug 15, 2011
Fly wheel gap echo 610 chainsaw
Yes indeed, you need a gap between the flywheel and the magneto! What about that gap? It appears that your post is not even a question, but a sentence fragment!
Apr 21, 2017 | Echo Garden
Echo chainsaw ran fine a few weeks ago. Today it won't turn over. The recoil is fine. The flywheel won't turn.
Pull the spark plug out of the saw and put a little cutting oil in the cylinder and try to turn it over.
Dec 08, 2016 | Echo Garden
Cs-302 fuel line replacement
How do I remove the Flywheel on a 1982 Echo chainsaw 302? I can't get to the fuel line since a piece got stuck under the flywheel.
Feb 01, 2014 | Echo Cs-302 Flywheel Assembly Cs 302
I have a echo cs5000 chainsaw. What is the coil to flywheel gap.
Kelly
Aug 15, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
My echo 400 chainsaw was working great and then it shut off. Now I cant pull the starter cord to start the engine. I pulled off the cover and it looks like the 2 pawls inside are engaged so that the spool...
This does not sound good, start by removing the starter, try to turn the engine by hand turning the flywheel, move it back and forth incase there is somthing trapped between the flywheel, if you cannot turn the engine this way, then somthing bad has happened inside the engine, it will now require a strip down to find out exactley what has happened
Mar 24, 2011 | Echo CS400 18" Chain Saw
How do you test the ingition coil on a echo 16 inch chainsaw?
Remove the ignition switch wire from the module. Set the module pole gap by turning the flywheel magnets under the module poles, insert a thin business card into the gaps, and loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the gaps don't close up at any point. Test for a blue, snappy spark at a fresh plug gapped 0.020". If nothing or very weak, replace the module. Hope this helps!
Nov 08, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
I am replacing a bad coil in my Echo SMR 2100. I need to know the air gap between the coil and the flywheel.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction abates and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH
Aug 06, 2010 | Echo Garden
Pullstart jamed removed putstart rope no problem
If after removing the starter the starter pulls easily but you can not turn the flywheel the engine is probably seized. Could be a piston failure or a bearing failure. check to be sure nothing is caught under the flywheel binding it up.
Jan 14, 2010 | Echo Garden
Where do I find the proper tools to remove the clutch assembly for an ECHO CS-345 chainsaw? I would also need a tool made to fit into the flywheel fins to prevent damage to the crankshaft while removing...
Aug 26, 2009 | Echo Garden
Garden Logo
13 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
