Question about Hunter (25417) Ceiling Fan
What is this item y59R120c - Hunter (25417) Ceiling Fan
How do I set up the answering system on the Vtech?
Try this:
press [menu]
scroll to "Answering Sys"
press [select]
scroll to "Ans Sys Setup"
press [select]
--- ( begin the setup item list )---
==1== as you scroll to each item to be set up,
press [select] to address that item
scroll through that item's choices,
then press [select] to confirm the choice selection
(chirps) and returns to the setup item list
==2==scroll to the next item
==3==scroll to the next item
==4== etc.
when finished, press [OFF] a few times to back up to "Handset #"
Feb 22, 2016 | Vtech CS6629-3 Silver Cordless Phone DECT,...
Tip
Recovering deleted items in Outlook 2003 and 2007
If you accidently deleted items like Emails, contacts, calendar, tasks, etc from your mailbox using Outlook, you can recover them as they are first transferred to the Deleted Items folder of that mailbox. But even if you delete them from the Deleted Items folder you can still recover them. This feature is enabled by default in Outlook 2007 but if you are using 2003 then you'll have to modify System registry.
Enabling recovery of deleted items in Outlook 2003
1. Start Registry Editor(Regedt32.exe).
2. Locate and click the following key in the registry
HKEY_LOCAL_MACHINESOFTWAREMicrosoftExchangeClientOptions
3. On the Edit menu, click Add Value, and then add the following registry value:
Value name: DumpsterAlwaysOn
Data type: DWORD
Value data: 1
4. Close the Registry Editor.
Now when you start Microsoft Outlook 2003 you'll be able to see a new option- Recover Deleted Items in the tools menu.
Recovering deleted items in Outlook 2007:
1. In the folder from where you deleted the item, or in the Deleted Items folder, click
2. Recover Deleted Items on the Tools menu.
Click an item and then click Recover Selected Items
NOTE: If an item doesn't appear in the Recover Deleted Items dialog box then you can't recover it.
on Oct 26, 2010 | Computers & Internet
Cheat codes for minecraft
Duplication Glitch
Follow these simple steps to duplicate items in Minecraft.
  • Step 1: Put item in your inventory.
  • Step 2: Drop item (More items dropped = more items duplicated)
  • Step 3: Pause and click "Save and Quit To Title"
  • Step 4: Play the world with dropped items
  • Step 5: Pick up items.
  • Step 6: Pause. Wait of the world to save.
  • Stp 7: Exit Minecraft.
  • Step 8: Open Minecraft again.
  • Step 9: Enjoy the duplicated items! (Works with diamonds)
Dec 08, 2013 | Android Apps
Change keyboard mapping
Create a program that uses a CUSTOM structure. Assign menus and submenus to built in calculator functions, or to a user defined program/function.
For additional details, see Chapter 17 Programming.
Here is an example from the manual.
:Custom
:Title "Vars"
:Item "L1":Item "M1":Item "Prgm1":Item "Func1":Item "Data1"
:Item "Text1":Item "Pic1":Item "GDB1":Item "Str1"
:Title "f(x)"
:Item "f(x)":Item "g(x)":Item "f(x,y)":Item "g(x,y)"
:Item "f(x+h)":Item "Define f(x) ="
:Title "Solve"
:Item "Solve(":Item " and ":Item "{x,y}"
:Item "Solve( and ,{x,y})"
:Title "Units"
:Item "_m/_s^2":Item "_ft/_s^2":Item "_m":Item "_ft":Item "_l"
:Item "_gal":Item "_\o\C":Item "_\o\F":Item "_kph":Item "_mph"
:Title "Symbols"
:Item "#":Item "\beta\":Item "?":Item "~":Item "&"
:Title "Internat'l"
:Item "\e`\":Item "\e'\":Item "\e^\":Item "\a`\"
:Item "\u`\":Item "\u^\":Item "\o^\":Item "\c,\":Item "\u..\"
:Title "Tools"
:Item "ClrHome":Item "NewProb":Item "CustmOff"
:EndCustm
:CustmOn
As to having a user program appear in the catalag, I am not sure you can do that. You may be able to have the program and its variables listed under the VARS and MEMory
Apr 06, 2012 | Texas Instruments TI-89 Calculator
What the enter code of murloc RPG?
I assume you mean item codes
Arcane Crystal Pendant, 5 Armor. +8 Intelligence Item Level 13. Rare Necklace, 32fad4e73aacbfe603fe487dd92533cd
Assassin's Blade, 3 - 5 Damage. +3 Strength Item Level 5. Rare Dagger, 2b42fbe4e8a7786a5ede7196dda2009f
Deathslayer, Emerald Blade, 9-16 Damage +25 Strength Item Level 20. Legendary Dagger, ab6627d02488d8b2868773e723fa54c4
Dragonskull Helmet, 400 Armor. +15 Strength Item Level 18. Epic Helmet, b76096738777404b54b617450104639f
Eternium Band, 0 Armor. +35 Intellect Item Level 16. Epic Ring, 1014cb602659291e718c1e7d8ddd3e4e
Geisha's Silk Kimono, 85 Armor. +50 Agility. Item Level 17. Epic Chest, e54fa6df48764bcf9b007d5b8f994deb
Hellfire Choker, 75 Armor. +8 Stamina Item Level 12. Uncommon Necklace, a53f9c3cb5f5cfe528ef94bc3a5b71c4
Lightforge Belt, 341 Armor. +9 Stamina. Item Level 15. Rare Belt, f6ad75ef1ab32154ef5e38d98257193c
Lightforge Boots, 424 Armor. +18 Stamina. Item Level 15. Rare Boots, abe905f768246d765472c3c3011cf463
Lightforge Bracers, 261 Armor. +10 Stamina. Item Level 15. Rare Bracers, f89a8621e099077f711d851a046f3d58
Lightforge Breastplate, 657 Armor. +21 Stamina. Item Level 15. Rare Chest, c519c769d5b5f003a15d8d440f182d25
Lightforge Gauntlets, 386 Armor. +9 Stamina. Item Level 15. Rare Gloves, f0a5460aa9c3c253ff48591149ca8036
Lightforge Helm, 526 Armor. +20 Stamina. Item Level 15. Rare Helmet, 2b3f59fc332d6b41e82004b6a01b21bc
Lightforge Legplates, 557 Armor. +14 Stamina. Item Level 15. Rare Pants, d21ea2c7ea7b624304c561dedbbab993
Lightforge Spaulders, 470 Armor. +15 Stamina. Item Level 15. Rare Shoulders, f1c4d3de306f0e1c21a6ebfb87acf975
Magister's Belt, 46 Armor. +21 Intellect. Item Level 15. Rare Belt, 6f66fdf2958135180caaff47e7756acf
Magister's Bindings, 35 Armor. +15 Intellect. Item Level 15. Rare Bracers, 876dfa68b59dc748922a4f41fe5ec30f
Magister's Boots, 58 Armor. +14 Intellect. Item Level 15. Rare Boots, a6d7b08a3661918afb247faa01c7c50c
Magister's Crown, 71 Armor. +30 Intellect. Item Level 15. Rare Helmet, 539a0cd3c30117eb6c89924c326ded97
Magister's Gloves, 52 Armor. +14 Intellect. Item Level 15. Rare Gloves, 0e146b974d2af70ede16c5d9bd2e4d04
Magister's Leggings, 76 Armor. +20 Intellect. Item Level 15. Rare Pants, 2945df577062a57e79f5d503df376191
Magister's Mantle, 64 Armor. +22 Intellect. Item Level 15. Rare Shoulders, 0367078991a9f977fc83e368603be298
Magister's Robes, 89 Armor. +31 Intellect. Item Level 15. Rare Chest, 55c279a7ff3e914993c5d3bb244be07b
Reforged Katana, 5 - 14 Damage. +15 Strength Item Level 18. Rare Sword, be8f6bb0fc46d73d3d2127abd2d980b1
Rune of Duty, 20 Armor. +7 Stamina. Item Level 8. Rare Trinket, 4de0edd84a5ac30876667dfe4e4009c5
Samurai Platebody, 570 Armor. +24 Stamina. Item Level 15. Rare Chest, 233fb5eca3e8bd88b820e75964cf1472
Seal of the Assassin, 0 Armor. +25 Agility. Item Level 15. Epic Ring, 63066f40fd5b28e390db3384b212a286
Shadowcraft Belt, 93 Armor. +14 Agility. Item Level 15. Rare Belt, c803bde9e49df539aa14082ed1b94de9
Shadowcraft Boots, 115 Armor. +21 Agility. Item Level 15. Rare Boots, cd288664eba2e60d5b078d41fea5a5b8
Shadowcraft Bracers, 71 Armor. +15 Agility. Item Level 15. Rare Bracers, 6bc3f89b33af3cc59ce9ce4f5d7144fc
Shadowcraft Cap, 141 Armor. +20 Agility. Item Level 15. Rare Helmet, 95efb4c45096600b12c772e0def87261
Shadowcraft Gloves, 105 Armor. +14 Agility. Item Level 15. Rare Gloves, 9d5541f805c7a0c85b6a43a314dfcc67
Shadowcraft Pants, 150 Armor. +25 Agility. Item Level 15. Rare Pants, 7ebfeed79bc005ca4e2b06f22088a1db
Shadowcraft Spaulders, 127 Armor. +22 Agility. Item Level 15. Rare Shoulders, 5a2e5f321b4c2175e4c04e168ed1510b
Shadowcraft Tunic, 176 Armor. +26 Agility. Item Level 15. Rare Chest, b5ca348dc4291ee71084e3c3ac193c63
Shimmerweed Branch, 69 Armor. +15 Intellect Item Level 12. Uncommon Trinket 852897b7ad210cc446262732f73cb919
The Emperor's Shield, 5214 Armor. +15 Intellect. Item Level 20. Legendary Shield, 3ffcd8a5055189bc00ad45fbe275ba6e
Worn Dagger, 1 - 2 Damage. Item Level 2.Poor Dagger, 8b8ffef1a9ffa52dbf6ac9170daa2fe3
Zul'Gurub Mango, Reset Zul'Gurub. Item Level 1. Epic Special Item, f6436f5b34a934c38deef9f775d0f582
Jul 30, 2011 | Video Game Consoles & Games
I am in the midst of having to move or possibly store my Wurlitzer 1015 and am wondering if there are insulated/protected covers for this expensive machine?
Have a look at this jukebox cover that is being auctioned on Ebay.
Here is the item listing number and location:- 220562227613 Stevenage Hertfordshire UK.
Regards
Alan Hood
ami-man
UK
Item number: 220562227513 Item location: stevenage, Hertfordshire, United Kingdom Post to: United Kingdom
Item number: 220562227513 Item location: stevenage, Hertfordshire, United Kingdom Post to: United Kingdom Item number: 220562227513 Item location: stevenage, Hertfordshire, United Kingdom Post to: United Kingdom
Mar 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
I list my item on ebay 24 hours ago and its still not on ebay. how can i solve this problem
first check if you successfully listed your item, you can check that if you already have the item in your active folder in your my ebay account under Sell. if not, you can try to list the item again.
you can also use the item number to search for your item, enter the item number in the search box. if your item will appear then your item is already and the auction already started. check the words in your title, make sure that you put in the same words that you have in the title of your item, if not your item will not appear. it really depends on what your item's title is, if you listed a car and the title is honda civic 2000 and you are searching for honda cars your item will not appear since the title of your item doesn't have the word car in it. make sure to put in the correct wordings when you are listing an item.
Sep 27, 2009 | eBay Auctions
Quickbooks items list
That depends on whether you are using QuickBooks, or QuickBooks Point of Sale.
For QuickBooks, one of the fastest ways to determine the number of Items, is to export the Items list to an exel spreadsheet. Once there, you subtract the number of rows used for header information.
This is important information to know, as with the quickbooks, you may run into a list limitation of 10,000 items ( or listings in the items list, this will include inactive items and sales tax items, non-inventory items and such.).
To export the lists, you should find a listing under the file menu.
If you are using Point of Sale, for versions 1 to 3, your list limits are 30,000. For versions 4 and up, there was a change to the databases that makes them pretty much unlimited. The latest version, 7, will tell you the number of items at the bottom of the items list screen.
Aug 23, 2008 | Computers & Internet
Hunter (25417) Ceiling Fan Logo
148 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
