Question about HP Officejet 5610 All-In-One InkJet Printer
Black lines down the paper when copying
When making copyies from the top (but not the glass), I get a black & a gray stripe down the length of the paper. any idea how to fix this!? I have tried cleaning the roolers I can see to no avail.
  • s_wolf Jun 23, 2009
    I thought that too at first, but I have also cleaned the glass and everything else I can think of. I only have the problem when sending the paper through the top and not when copying directly from the glass.
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab31
Posted on Jul 17, 2009
  • HP Expert
  • 398 Answers
You have gunk on the scanner glass the thin one
Posted on Jun 23, 2009
  • quennie732 Jul 08, 2009
    Ok Here is the fix but you may think I'm CRAZY, it took me 6 months to find this one. Your machine as far as the top part is concerned is a 3 legged table grabb the "missing leg" corner and put your knee on the lower portion and reef up, straight up. Not crazy reefing but it takes some pressure. See your scanner is slighly crooked. This will fix it! -Carl Please let me know if I helped.
Panasonic dp3010 copier stripes on paper
Not exactly sure what you are asking but if the problem is that you are getting fine lines down the paper (the copy is ok though) then take a real close look atr the glass platen (the plate glass in which the paper goes on. Assuming you are using the ADF (Automatic Document Feeder) area. This area is usually about an inch wide by 8.5" long. Look for either "White out" or black ink on the glass (it can be as small as a dot) clean this mark off with glass cleaner and you problem will be solved. Sometimes it helps to orientate your copy with the line on it to the machine to locate the mark causing the issue.
Good Luck!
Mar 01, 2012 | Office Equipment & Supplies
I have the SCX-4521. When I feed paper into the top to make copies, the copies come out with a black line in the middle of the page from top to bottom. However, if I make copies by laying the page on the...
Have look where the paper feeds into the tray at the top.
Most likely there is a piece of rubbish stuck in there, another piece of paper or some fluff or something. Blow it out and give it another try.
If this doesnt work open the lid and have a look to the far left of the plate glass. you will notice a small plate glass seperate from the main plate running parallel with the main plate. Clean this with a damp cloth and some window cleaning detergent. Sometimes correction fluid gets wiped off onto this portion which acts as the Scanning Region for documents inserted on the top feeder. This causes a "permanent" black object being scanned for copying, hence the black stripe.
Regards,
BD
Sep 02, 2010 | Samsung Office Equipment & Supplies
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Savin 2545 document feeder gives a gray band on the copies
Yes - surprisingly - we had the same problem, the gray stripe along the side of the page only showed up when the original was fed through the document feeder on top. Cleaned the small area of glass under the feeder repeatedly with no change to the resulting stripe, but then while cleaning the upper roller, above the area of glass where the scan lamp illuminates during the copying from the ADF, we found a small piece of paper adhering to the top roller in the paper path, cleaned it off, and no more band. We didn't see the bit of paper on the upper roller until we rolled it while cleaning. Still can't figure how that made a stripe....but hope this helps you.
Feb 22, 2010 | Savin 2545DP Black and White Copier
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
When I use the automatic document feeder on my xerox copycentre C20 I get a black line running the length of the page. If I make a copy from the glass, one sheet at a time, it is fine. Is there a way to...
You have something on your "**** glass", the narrow piece of glass that the scanner "looks" through during adf use. Get some window cleaner or rubbing alcohol and clean it with a damp cloth. Often, it's correction fluid (Liquid Paper). A little dot is all it takes because the paper is traveling across the dot, effectively drawing a line down the length of the page.
(Please rate this response as I'm trying to obtain the next level.)
Aug 04, 2009 | Xerox CopyCentre C20 Black and White...
Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Dec 13, 2008 | Brother MFC-7820N Printer
PAPER PRINTING OUT WITH BLACK LINES AND MARKS
When coping I have a black line down the left side of the page. This only happens when I'm copying NOT when I'm printing off a document from Word or the Internet on my computer. How can I get rid of this black line?
Aug 14, 2008 | Office Equipment & Supplies
Black line on faxes
Check carefully the glass, a very small point of ink or anything else can cause the black stripe. usually  it is that the problem. use windex to clean it.
Apr 15, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
HP Officejet 5610 All-In-One InkJet Printer Logo
140 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
