Question about Lakewood HV 18-c Floor / Box Fan
Lakewood fan model hv18 power switch
The switch is broken. Do you have replacement switch
5 Suggested Answers
  • 2976 Answers
SOURCE: have a lakewood shop fan pedestal type with 3
The switch has numbers on it. Mark the wires. Just connect the new switch the same way.
Posted on Jul 26, 2009
MOTORWIZJ
  • 1363 Answers
SOURCE: I need a replacement motor, 60 HZ 2.7 amp, for a
GRAINGER.COM ... .GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
Posted on May 28, 2010
motor1258
  • 6674 Answers
SOURCE: switch broken
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
Posted on Jul 10, 2010
mcdevito75
  • 1970 Answers
SOURCE: are replacement motors available for these fans?
mcdevito75 here, If the fan is not too old I would figure yes, but a replacement motor will cost as a new fan, if not more, then you have to install and the blades are a presss fit to the motor.
Posted on Jul 28, 2010
Replacement wheel for Lakewood Heater Model 7101
I did the drill think once. but today when trying to repair an old Lakewood 7101, I removed the two screws holding the front cover in place (top and bottom). the cover slides down and out. and underneath I see a large plug that can be unscrewed to drain or fill the heater!
Sep 02, 2012 | Lakewood Heating & Cooling
Are replacement motors available for these fans? Lakewood HV 18 Lakewood HV 21 Lakewood HV 21T
Jul 27, 2010 | Lakewood HV-18 Floor / Box Fan
Switch broken
Jul 10, 2010 | Lakewood 200I Floor / Box Fan
Lakewood heater 792 will not work
The bottom switch is bad. Unplug bottom wires and touch them together, if heat and fan comes on your switch is bad.
Feb 11, 2010 | Lakewood 792/JR Utility Heater
My lakewood HV18 just stopped. Spinning the shaft
I think you need to buy a new fan. Unless this thing cost several hundred dollars it isn't worth rewinding and a capacitor isn't likely to cause it to stop working, the cap is for STARTING it spinning anyway and sometimes they are used to HELP it run better, but it will try to run if you spin it and since your's does nothing, more than likely the windings are gone.
Sep 09, 2009 | Lakewood HV 18-c Floor / Box Fan
Need to replace the switch that has ,hi,low,med off on nit? please Help
you have 3 control wires (the 3 speeds) and a common wire. the common wire will go directly from the fan motor to the power source/cord and the other 3 leads will run through the switch. you could even use a standard dimmer-style lighting rheostat and connect it to the common and "high" fan speed wire and have infinitely variable fan speeds. hope that helps.
Apr 30, 2009 | Lakewood HV-18 Floor / Box Fan
Cleaned a fan, now it's broken!!!
Is this the speed switch itself? These multi-speed fans have 4 or 5 wires which come from the motor which go into the speed select switch. The wiring may have the ends stripped, and this stripped end just pushes into the hole on the switch, and a little metal piece grips that stripped end.
Anyway, one possibility is to contact the manufacturer- look on their website or give them a call, see if a tech can give that info. Another poss. is to locate an identical fan and note the wiring locations on it. You can also experiment trial and error, though caution needs to be exercised here.
Jul 31, 2008 | Lakewood HV 18-c Floor / Box Fan
Power switches
what do the switches look like? can you supply a picture?
Nov 10, 2006 | Lakewood 7101 Oil Filled Radiator Heater
Lakewood HV 18-c Floor / Box Fan Logo
46 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
